92 Disk/Drum to 89 1LE Proportioning Valve Question
Old Nov 3, 2007 | 11:16 PM
tta1415's Avatar
Car: 1992 Z28
Engine: LC2
Transmission: GM 2004R
I did this swap about a year ago and I've searched a few times and it seems I've come up with contradictory info.
My 92 Z was a front disk rear drum car (non G92) but now it's 1LE front with a 9 bolt PBR rear (all pulled from a scrapped 89 TTA)
What Proportioning Valve do I need?
Thanks for any info you can give.
Jim
Old Nov 4, 2007 | 07:07 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 92 Disk/Drum to 89 1LE Proportioning Valve Question
Originally Posted by tta1415
My 92 Z was a front disk rear drum car (non G92) but now it's 1LE front with a 9 bolt PBR rear. What Proportioning Valve do I need?
The following from Dan Burke's site: GM part #10136840 1990-'92: M1.5 tube nut threads.
JamesC
Old Nov 4, 2007 | 07:34 AM
tta1415's Avatar
Car: 1992 Z28
Engine: LC2
JamesC
Ok, here is what I've found during my searches.
My car was originally a J41 with valve 10136839
The donor car was a late 89 with valve 10136840
GM part#s 10136840 and 10136841 have been superseded (combined) by GM to part# 10136839
But beginning in late 1989 through the end of production in 1992 this 10164112 was used on ALL J65 and 1LE equipped cars.
So do I need 10164112 or GM Part number 10136839? (the new # for 10136840) or are they both the same.
Gm parts direct has them both and they are both the same price.
Jim
Old Nov 4, 2007 | 03:19 PM
JamesC's Avatar
Here's the whole quote from Mr. Burke:
14089496 1989 1st design: M1.0 tube nut threads (For 1982 - early 1989 applications) [This is the one that I used on my 85 to upgrade both front and rear to 1LE. As far as I know, the only difference between the 496 valve and 840 is the threads.]
10136840 1989 2nd design: M1.5 tube nut threads (Late 1989)
Why not simply use the valve fom the donor car if the threads are the same?
JamesC
Old Nov 4, 2007 | 07:05 PM
tta1415's Avatar
Car: 1992 Z28
Engine: LC2
JamesC
It was scrapped after the swap
Old Nov 4, 2007 | 08:23 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
You need the 10164112 valve for your '92.
Ed
Old Nov 22, 2007 | 09:22 AM
Cadillac's Avatar
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
I am going to have the exact setup soon: 1LE fronts, nine bolt 3.27 rear with PBR's. I went and got a whole new MC for the swap: Part# 18014287.
Ed and James are the best.
Old Dec 26, 2007 | 01:01 PM
pzoom's Avatar
Car: 91 Firebird Convertible
Engine: 305 TBI
Where is a good place to get this part 10164112? I tried to order via GMParts Direct and I got an email saying it is discontinued.
I have a 91 with front disc/rear drum and I had a 95 rear with disc installed. It works, but not very well with the stock proportioning valve.
Old Dec 26, 2007 | 08:52 PM
cdamiano's Avatar
What options is this 10164112 valve for?
4 whhel disk? and/or 1LE?
Old Dec 26, 2007 | 11:33 PM
Cadillac's Avatar
I ordered the whole MC that came with the prop valve. That may be the only option to get one new. Otherwise, hit the Pick-n-Pull.
4 wheel disk.
Old Dec 27, 2007 | 10:30 AM
pzoom's Avatar
Engine: 305 TBI
If anyone is looking for a new one the following dealers have them in stock:
502-348-3964 KY
803-750-4800 SC
336-760-7038 NC
I got mine from the KY dealer for $104 incl shipping.
Old Dec 27, 2007 | 01:26 PM
ebmiller88's Avatar
If you are looking for these valves they are now discontinued, as are the valves for the earlier 1LE cars. Good luck!
Ed
Old Dec 27, 2007 | 03:59 PM
Cadillac's Avatar
502-348-3964 KY
803-750-4800 SC
336-760-7038 NC
I got the whole MC with the correct prop valve for ~$160 FWIW.
Vintageracer
Jan 10, 2020 05:33 PM
gta90
Sep 15, 2015 04:00 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
redmaroz
Aug 16, 2015 11:40 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
