What is the threaded fitting, front brake, rubber line
Old Dec 31, 2007 | 01:09 AM
Twilightoptics's Avatar
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
The female end of the rubber hose on the front brakes from the calipers is what fitting?
Is it the Metric 10x1 bubble? Or a -3AN Female?
I'm confused.
I'm putting my stock brakes on a project car and trying to adapt the old rubber lines from the calipers to 3/16 Inverted Flare.
-Paul
Old Dec 31, 2007 | 08:16 AM
Re: What is the threaded fitting, front brake, rubber line
Yes it is metric bubble flare. I don't know for sure what size.
It is GUARANTEED NOT to be any -AN size.
Rather than do all that "adapting" so you can use old disposable hoses, just go buy new rubber hoses for a 82-83 car; or for any other older car, whose hoses might fit better than the SUPER LONG ones for these cars. The steel lines in cars before about 84 had 3/16" IF fittings.
Old Dec 31, 2007 | 09:11 AM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
10mmx1.0 female is the correct size.
Old Dec 31, 2007 | 09:28 AM
Weird because the new hose doesn't look like it's bubbled or rounded... it looks straight more like an AN.
My project car needs the long lines. That's why I was going to try and use stockers.
Will the old 82/83 line fit the caliper fine?
Old Dec 31, 2007 | 09:39 AM
It's not -AN. Believe that. There are no -AN fittings on these cars from the factory, anywhere.
Those calipers were the same from 1969 until whenever they quit using them.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
