2009+ CTS-V brake upgrade
Car: 87' IROC
Hi guys I am working on a 2009+ CTS-V brake upgrade for my Camaro. GM brake swaps are popular around here and these are about as nasty as they get. These things work well on a 4200lb CTS-V with 200hp more than my car. I should be good to go.
Fronts are 6 piston monoblock Brembos on 14.66" rotors. Calipers are over 13" long,
and have the biggest pads I have ever seen.
Rears are 4 piston Brembos on 14.50" rotors. Calipers are about as big as my current front Wilwoods. These are about 90% the same as 2010+ Camaro rear brakes. Except they put the caliper on the front of the rotor instead of the rear.
The beauty of this setup is they bolt on the same as 2010+ SS Camaro brakes. So brackets are available. Price is expensive as far as GM swaps go, about about half the price of a comparable aftermarket kit.
I had the calipers powdercoated in a dark charcoal metallic with a silver Brembo logo. Rotors are OEM CTS-V except I had an ALMS team slot them for me. Pads are Hawks HPS. They will be going on in the next month or so.
Front
Rear
Rotors
Full kit
Quick mockup in wheels.
and have the biggest pads I have ever seen.Rears are 4 piston Brembos on 14.50" rotors. Calipers are about as big as my current front Wilwoods. These are about 90% the same as 2010+ Camaro rear brakes. Except they put the caliper on the front of the rotor instead of the rear.
Front
Rear
Rotors
Full kit
Car: 1991 Trans Am
Re: 2009+ CTS-V brake upgrade
What are your rear calipers off of? Are they the 09+ ctsv rears? Do you think the front setup would fit an 18" wheel?
Car: 87' IROC
They are 2009+ CTS-V calipers all around.
GMHTP managed to fit these inside an 18" wheel by using a 14" Z06 rotor rather than the 14.66" CTS-V rotor. Not sure if the 14.66" rotor would fit. But I will try it as some point.
http://www.gmhightechperformance.com...s/viewall.html
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Those are going to be sweet. They will fill out those 19's better than the old wilwoods.
Car: 1991 Trans Am
Are you going to do anything for mounting the rear calipers aside from just the adapter bracket? I would assume these would have the same pad knock issues the older cts-v rear calipers do when mounted to our cars?
Also, what about a parking brake? What do you have in store for that?
Car: 87' IROC
Car: 87' IROC
Regarding the e-brake. I am currently evaluating my options. I am hoping to use the factory CTS-V e-brake, but there are challenges. If that doesn't work out I plan to use a spot calipers like the link below.
http://www.ipsco.org/Custom%20Servic...ng%20Brake.htm
Car: '91 1LE
Engine: 377 w/Stealthram
Axle/Gears: 3.42 Torsen
I thought the '09 and up CTS-V's used an electronic ebrake. When the button is pressed the ABS system builds and holds pressure to the rear calipers. No cables, only wires and programming.
Car: 87' IROC
Nope it is a normal cable pulled drum style e-brake. I will be ordering some parts today.
Car: '91 1LE
I was partially right...no cables, computer controlled
Electric Parking Brake
An electric parking brake is standard on
the 2009 Cadillac CTS-V. An electric park
brake (EPB) release switch replaces the
park brake pedal and release handle used
on the manual system.
The electric park brake module
assembly has an internal motor, apply
actuator, release actuator, and temperature
sensor. The control module also
contains the logic for applying and
releasing the parking brake when
commanded by the parking brake switch.
See the July 2008 issue of TechLink for greater detail.
Car: 87' IROC
Can you tell me the rotor width? Love the slots on yours, the stockers look a little bland, being that huge with a solid face. Could you do rotors for other people like that???
Car: 87' IROC
The slotting was done by an ALMS / Indy / Nascar team in Indiana. I can't say which team, but its one of the big boys. I purchased them through Bruce at Raymond's Performance. Good guy to deal with and he has all the connections with the race team.
http://www.raymondsperformance.com/contact.aspx
I will post up some specs and pictures of the rear rotors later.
John
Car: 87' IROC
Part Numbers:
Front
25912477 - caliper
25912967 - caliper
25940447 - pads
25940448 - x2 caliper pin kit
1771105 - x2 rotor
Rear
25911138 - caliper
25911233 - caliper
89047744 - pads
1771051 - x2 rotor
E-brake
25851190 - backing plate
25851205 - backing plate
25693149 - cable bracket
25693150 - cable bracket
25814678 - shoe kit
25867413 - x2, shoe lever arm
25867414 - x2, shoe leveler
20823795 - cable
20823866 - cable equalizer
18K2087 - spring kit
Raybestos H7363 - hardware kit
Front
25912477 - caliper
25912967 - caliper
25940447 - pads
1771105 - x2 rotor
Rear
25911138 - caliper
25911233 - caliper
89047744 - pads
1771051 - x2 rotor
E-brake
25814678 - shoe kit
20823795 - cable
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
^ giant multi piston calipers are close to coming to an end, its run its course, next evloution will be 2-3, 2-4 piston calipers per wheel spaced out, plumbed for progressive stopping power as needed.
Car: 88 Trans Am Hardtop
Engine: 350 L98
Transmission: Stock 700R4
Axle/Gears: 3.27 Aussie 9
COTM Editor
Car: '91 TA vert
Engine: turboLSx
Probably, but I just dumped a bunch of money into my other car's bbk. I think I should put brakes on hold for awhile.
Ala Merc AMG stuff? Hrm. Weird. I figured fixed solid calipers would still be the big dogs. Motorsports like F1, BTCC, NASCAR, AussieV8s aren't running multi calipers are they? My mindset with that train of thought is that technology and "bling" trickles down from the racing divisions.
On Probation
Car: 87 IROC-Z
Engine: LsX
Transmission: MN12 6speed
Axle/Gears: 3:42
Beautiful brakes .!!
I was considering a rear set to go with my v1s, with time of course .
Keep us updated let us know what rear brackets you use.
Car: 87' IROC
Car: '91 TA vert
Engine: turboLSx
Car: 87' IROC
There is a picture attached above that shows most of the assembly.
Car: 87' IROC
Got my front rotor hub holes enlarged and was finally able to mock up the brakes in the wheel. Brakes fit well. You could squeeze these into an 18, and it would look awesome. I have about 3/4" of clearance between the face of the caliper to the spokes. More than I would like but inevitable due to how big the wheel back pad had to be to clear the front spindle.
Lots of pictures:
Car: '91 TA vert
Engine: turboLSx
You think I could stop by sometime with my c6 18" wheel and see if it'd fit inside?
Is the V ebrake stuff different bolt pattern completely or is it clearance issues?
Oh and I love the duct tape sandal.
Car: 87' IROC
The 3 bolt pattern on the flange seems to be the same. But the caliper radial offset is different and the e-brake backing flange requires a different offset. I'm going to run something similar to Ed's C5 setup but will be customized to fit the V parts.
Car: 87' IROC
And here are the rears. Unfortunately the rear calipers are thicker than I was told. So I have interference with the caliper face and the back of the spokes. I haven't played with it much, but I think 1/4" will be more than enough. Shouldn't be to bad.
Car: 2012 F350 lariot/1991 Camaro RS
Engine: Powerstroke/6.0
Transmission: 6R100/4L80e
Axle/Gears: 3.73/3.42
and I believe the have already built a rotor stator brake for a car where is a full rotor to two full size brake pads with 12 pistons all the way around
Disc brakes and ABS were invented on planes first so its just time now
and acft like a F16 has 6 piston 3 rotor 3 stator carbon brakes
Car: 87' IROC
Started working on the front brackets. These calipers have very long mounting lugs which means the bolt holes are very close to the existing bolt holes in the spindle. To get them to sit nice, the lower caliper bolt needs to sit right where the steering stop currently is. Then the caliper bolts sit right below the spindle bolts. It will be an exercise in tight fitment. However if I get it right, I think they should look good and won't hang as low as Ed's brackets for 1st gen CTS-V.
Ed's brackets.
Ed's brackets.
Car: '91 TA vert
Engine: turboLSx
Ed's brackets.
Ed's brackets.
Aren't those brackets for the c6 Z51 rotors, not the 14" zo6 ones? (That's Dewey's picture, right?) AFAIK, you can bolt the gen1 ctsv stuff on with LS1 brackets + zo6 rotors.
Car: 87' IROC
It does look like the 13.4 Z51 rotor. However after mocking up the brakes last night the lugs end up in basically the same place. In fact the lugs are incredibly close to aligning to the factory dust shield holes. If they were just a little closer I would seriously consider using the factory holes and drilling them out to the necessary 14mm.
Car: 87' IROC
I have completed reverse engineering the Dana 44 flange. Does anyone know where to get longer flange studs? A normal bolt or nut will not fit.
Car: 87' IROC
I started working on the front brackets. Its modeled after Luke Skaff's Gen 1 CTS-V / 2010+ SS bracket.
I started out using 1/4" MDF due to its workability. I got the general fitment worked out but its tough due to how the caliper mounting bosses are shaped. The lower spindle bolt doesn't have enough meat around it. So I am going to have some material milled off the calipers to make the bracket more robust. Also I am not crazy about the bracket being only 1/4". I think a 1LE offset hub would have been better. I may see what Tobin thinks about running a 1/16" to 1/8" spacer between his hubs and the rotor. That would give me a 5/16" or 3/8" thick bracket. Much better.
Here you can see the odd shape of the bracket due to the rounded shape of the caliper lugs. I plan to mill off the "points" on the caliper to eliminate the need for two "dips" in the bracket.
Here you can see the other side. The lower spindle bolt interferes with the body of the caliper. I am going to see how a socket head cap screw fits. Worst case I will mill a very small relief in the caliper. Or if I end up with a 3/8" thick bracket, I could probably run that bolt in the opposite direction and just tap the bracket.
Finally here you can see the steering stop interferes with lower caliper bolt. I am going to hack up the steering stop to get it to work. I would prefer not to remove it all together.
Car: 87' IROC
I got the calipers milled today. I am much happier with the Rev A bracket. Much more meat where it needs it. I still need to find a solution for the lower spindle bolt head clearance and the steering stop.
Car: 87' IROC
Starting to come together. Got the steering stop clearanced for the lower caliper bolt. I was able to get everything bolted up for the first time. Just need to work on the clearance for the lower spindle bolt. I am pretty happy with how the caliper is clocked. I was shooting for perfectly vertical but its only a few degrees off. Better than some of the gen 1 CTS-V swaps I have seen.
Do what I did, cut off the steering stop and use a big head allen bolt to secure the caliper there, then when done put a small plastic cap or whatever over the bolt head if you want. It will act as a steering stop just fine, not a problem at all.
I really like what you're doing...most awesome brake swap period.
Car: 87' IROC
That is a good idea. I thought about that originally, but wasn't sure I wanted to introduce bending into the bracket, especially if its only going to be 1/4" thick. Good to hear it is working well for you. I will have to think about it.
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
Beautiful brake kit!
Car: 87' IROC
Well I made some progress on the rear brakes. They are a pain for sure with the e-brake. In short the its like getting a square peg into a round hole. The CTS-V axle flanges are three bolt circular. The Dana 44 on the other hand has the standard GM 10/12 bolt trapezoidal flange. On top of that, the Dana has the standard high offset from diff flange face to axle flange. Where as the V is very low offset. So what I need is a bracket that is very thin to accommodate the bolt in axle plate yet very thick to space out the caliper mount and e-brake mounts to the rotor.
Large black dust shield is the CTS-V dust shield and provides mounting points for the drum e-brake.
E-brake stuff. This is my attempt at drum brakes. I'd appreciate any input if this looks right or not.
With caliper mounted.
Here you can see the experimental mdf bracket, haha. The stud on the left is one of two mounting studs for the e-brake cable. The two unfilled holes are two of 3 holes for the CTS-V 3 bolt flange.
And here you can see the e-brake needs to be spaced out around an inch.
Car: 87' IROC
Well I got the rear bracket completely designed. It will be 6061-T6 AL.
4 small holes and center pocket are for the axle retention plate. The 2 holes on the left are for the caliper. Three larger holes at 12:00, 6:00, and 9:30 are for the dust shield and e-brake mount. Two larges holes at 2:00 and 4:00 are for the e-brake cable bracket. Two very large holes on the left side are for lightening. Weight is about 2lbs per bracket.
Stresses look good.
Deflections looks good.
Stresses look good.
Car: 86 Trans am, 91 Camaro RS
Engine: 355 Sbc, nothin yet
Transmission: 700r4- both
Ur on a roll.John.. looks fantastic!! I'm finishing up my 2010 brembo swap now. I also am running 19s, but I'm currently waiting on flush mount valve stems as mine are positioned inside the wheel. Very good work.
BTW.. do u plan on resusing the mini dust shield that sits behind the hub, but up against the spindle?. I thought about cutting the shield off the backing plate and drilling a hole for the bolt to mount up. I am running the Racecraft drop spindles.
Car: 87' IROC
Any pictures of your whee/brake setup?
