1LE brake project...
Old Mar 23, 2004 | 12:40 PM
  #51
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Yep, thats my state, but I'm not into sports myself.
So how does it work that you keep the same rear axleshaft??
I assume a kit is avaliable for rear to do this?
I can get 1LE front spindles w/o problem
Old Mar 23, 2004 | 01:53 PM
  #52
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Like I said, you pull the axles out of the rear and change backing plates, reinstall the axles and bolt all the brake stuff off. Baer makes a kit for around $800, AndyZ28 offers one too for right around there, and there's others out there that can do them.
But again, there's probably better brakes out there. I just put together 13" x 1.1" C4 HD brakes for 3rd gens and they look great. I will have these on my RS by the weekend.
Ed
Old Mar 23, 2004 | 03:09 PM
  #53
Dale's Avatar
Engine: 350 S-TPI
So you keep the same axle if you get the kit?
If I was able to get all the parts from wrecked cars, I would need to swap the shafts then. Alright, I think I got it figured out.
Time to make some green first
Old Mar 23, 2004 | 11:11 PM
  #54
SLP IROC-Z's Avatar
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
Originally posted by ebmiller88
Talk about resurrection! Here's a little advice. I highly advise you to paint or otherwise protect the bare metal areas on the rotors, both front and rear, if your car isn't a daily driver. My Iroc's been sitting a while and all rotors are rusted like crazy. I'm gonna have to pull them off and sand or bead blast them clean and then paint them to keep them protected.
Ed
i clear coated the outside part of the rotor tonight, its high temp clear, solvent resistant as well. this should work ok. the part of the hub that mates to the wheel will be coated with a lot of never seize, i figure that should help out too. hopefully when i have more money i can get the rotors zinc plated or whatever it is. im not even sure of the quality of them so i shouldnt dump money into em if they suck, i hope they are decent rotors tho.
BADNBLK
Convertibles
Sep 21, 2015 07:56 PM
dbrochard
Sep 19, 2015 08:13 PM
Necron
Brakes
Sep 14, 2015 12:45 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
