Everything that is related to brakes replaced.... car still pulls to left....?
Old Mar 19, 2004 | 07:16 PM
HamSpiced's Avatar
Car: 89 Camaro I-Roc z
Transmission: Th700r4
jsut liek the title states....
ive replaced the:
Rotors
pads
calipers
caliper brake line bolts
Caliper bolts
Inner and Outer Bearings
Dust Cap
Replaced the Rubber lines with Steel Braided (EARLS) lines
Replaced ALL Hardlines with Stainless Steel Hardlines...(inlinetube.com)
Replaced Proportioning Valve (stock replacement)
All new fluid
so i ask you... what the hell is making my car pull to the left???
Old Mar 19, 2004 | 07:32 PM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
Well, have you checked the front steering linkages for slop or play, how bout bad control arm bushings (toe changing when you hit the brakes)? If you have a auto tech as a friend, see if he has a infared thermometer, check temps on both calipers, they should be even, if not the hotter one is doing more stopping or somehow not releasing Usually the caliper slides are the culprit, but if you used a silicone lube on the "tubes" and o rings and the calipers "float " back and fourth on the pins, it`s not the slides. Shouldn`t be that hard of a problem to fix
Old Mar 19, 2004 | 11:16 PM
MYBLUZ's Avatar
Car: 1991 Z28 1LE A.K.A The blue rocket
Engine: Blown 383
Transmission: Full manual 700R4
well said greesemonkey. Just when you think you have looked at it from every angle, someone comes along and shows you something new.
Old Mar 19, 2004 | 11:21 PM
MAXJEFF's Avatar
Car: 92 RS, 95 1500, 91 SHO
Engine: 355 LT1
Axle/Gears: 410's
Does it only pull when you brake? Have you checked your tires? If you don't have directional tires try swapping the front tires. That may fix the pull. I know it sounds weird, but it's fairly common.
Old Mar 19, 2004 | 11:33 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
When you bled the front calipers, did the fluid flow evenly, or was one side still going slow?
Is the passenger side line routed next to the exhaust pipe anywhere?
Old Mar 20, 2004 | 12:37 AM
HamSpiced's Avatar
yea, the passenger side still bleed really really slow....
the driver side bled really fast...
but the pass side bled super slow.. i cant figure that out...
the only thing i havent replaced yet is the master cylinder... should tha tbe next?
Old Mar 20, 2004 | 04:39 AM
I`d look at the hard line from the prop valve to the flex line real close, sounds as if were pinched to me, with the fluid traveling slow, the master feeds both front tires from the same port, so no master cylinder. That line goes under the oil pan, could have been pryed aganist or something to restrict the fluid.
Old Mar 20, 2004 | 06:03 AM
Cam84358's Avatar
Car: 84 Camaro
Engine: v6 to v8 swap 357ci chevy
Transmission: TCI Turbo 350
You may have damaged the line when you installed it.Theres not alot of room to work with.I removed the y pipe from my headers and worked the line in from the back.
Old Mar 20, 2004 | 11:27 AM
Chickenman35's Avatar
Car: 86\92 Mutant
Engine: 355CI 430HP
Transmission: T-5 with mods
Axle/Gears: 7.625", Eaton Posi, 3.73
Yep...agree with the others. Check the hardline. It's either pinched, blocked or restricted in some manner. Double check the flares on the hardline to that wheel...make sure that they are not restricted.
Old Mar 20, 2004 | 02:01 PM
HamSpiced's Avatar
the line was fine, it went in really easy with no problems. ill add that before i changed the lines it was still doing this....so i dont think its a problem with the line... it cant be a faulty caliper because ive already brought the caliper back cause i thought it was faulty...
Old Mar 20, 2004 | 04:01 PM
You might try removing the banjo bolt from the caliper, and have a helper press the brake pedal (but not to the floor) and see what amount of fluid flows from the end of the flex line. Be sure to protect your eyes and paint while doing this, as the fluid could spray anywhere. This could rule out the hardlines and prop valve.
I'd think the line(s) from the MC to the prop valve should be fine, as one caliper appears to work fine...
Old Mar 20, 2004 | 10:08 PM
HamSpiced's Avatar
I think i found out the problem.....
see if this sounds right....
in doing this overhaul i was reattaching the line to the caliper, well i tightend too tight and snapped off the caliper line bolt so i bought a new one... and finished that caliper line (passenger side)
i never replaced teh drivers side caliper line bolt... so im thinking no duh more fluid is flowing through the stock caliper line bolt, theres 15 yrs worth of corrosion there so the opening has to be bigger... im going to replace that bolt soon, will hopefulyl solve this ****e dup problem....
but does that sound about right?
Old Mar 20, 2004 | 11:31 PM
Possible.
You can clean out the passageway in the bolt with a piece of stiff wire.
You didn't use pipe tape or thread sealer on those bolts, did you?
Old Mar 21, 2004 | 02:37 AM
HamSpiced's Avatar
of course not....
Old Mar 21, 2004 | 09:06 AM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Your suspension could cause your car to pull when braking. Hows the alignment? Was only one shock replaced at one point? Anything bent? Worn bushings?
Old Mar 21, 2004 | 09:43 AM
HamSpiced's Avatar
did you read all of the thread?
the problem isnt in the suspension. We first noticed a problem in the bleeding sine one side (passenger) bled much slower then the drivers..
a slwer rate in the passenger means the drivers does more work, which would result in a pull to the.....LEFT
winner winner chicken dinner.... heh i amaze myself....
new suspension will be going in soon though, tirods, lca's, panhard rod, steering ETC ball joints and what not... as soon as someone posts em in the classifieds ill be putten them on
Old Mar 23, 2004 | 09:22 PM
HamSpiced's Avatar
heres the deal...
ITS FIXED...
i bought a new bolt to replace the drivers side caliper line bolt... and it looked fine... im like ohwell.. i bleed the system , try it out... it still steers to the left... so im like **** IT...
i check the caliper line bolt on the passenger side (the origional one i replaced....)
(in case you didnt know what a caliper line bolt looks liek iots a bolt with a hole in the side and a hoel down the middle so the fluid can get through like so )
and i take the caliper line bolt i bought to repalce the one i broke off at the begining of this entire ordeal....
this is what i see
Murrays sold me a ****ing DEFECTIVE bolt... they never drilled completly through the bolt so no fluid was getting to the other side..... WHAT THE ****....
so cause of this bolt ive bought
new calipers (30 bucks)
Steel Braided Brake lines (70)
Brake Pads (60)
Hardlines(200)
Brake Cylinders (15)
thats right because of a ****ign bolt i wasted 375 bucks......
im going to murrays tomorrow and complaining, im going to write a very detailed letter to the manufacturer, and include all my receipts.....
Thanks for all the help tho guys
Old Mar 23, 2004 | 11:51 PM
Glad you found the problem!
Good luck with the complaint...hope they'll cover some, if not all, of your parts expenses.
Old Mar 24, 2004 | 04:57 AM
uh....wow! never saw that one coming. Note to self, no bolts from murray:nono:
Glad ya found it enjoy it now!
Old Mar 24, 2004 | 05:15 AM
Jukka's Avatar
Car: "My American Dream"
Engine: V8
Transmission: auto
allways look at the bright side of life: Now you have all new brake components in front
Old Mar 24, 2004 | 09:28 PM
HamSpiced's Avatar
~UPDATES~
I talked with the manager at Murrays....
She talked with me about my problem and told me what will probably happen. she gave me the manufacturers number and their name is Motor Mite... she said that i need to make a copy of all my receipts (two copies) motor mite will request a copy and murrays will...
Murrays will run the receipt of my origional purchase of the bolt... and will check the dates from that bolt to the other purchases ive made to verify that i bought the bolt before the other things..
then the claims people at motor mite will enstate a full or partial reimbursement but she said since she is the head manager at murrays she will suggest a full re-imbursement cause not only did i miss 2.5 weeks... AND my spring break... i was doing All of this work on my car... in the cold, 20* michigan weather...
im not getting my hopes too up... not untill i get the check in hand... but so far thing slook pretty good....
Old Mar 24, 2004 | 09:32 PM
HamSpiced's Avatar
not just upfront... Everything brake related was replaced... the rear pads, shoes, springs, wheel cylinder..
All of the brake lines were replaced... not just the fronts
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Adamki2000
Brakes
24
Dec 20, 2015 10:40 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
