LS1 rear brakes?
Old Dec 20, 2003 | 09:19 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
LS1 rear brakes?
I have been reading about swapping the rear brakes on my 92 to LS1 rear discs. I will probably try to find a disc rearend at the auto recycling center and do the conversion off the car. It seems easier and that way I can drive the car at the same time.
My questions are:
For those who have done this, how is the swap? How does the car stop? Would you recommend this swap to someone?
What about parts? Can high perf. pads be used? What about drilled rotors?
Can any late model, C5 vette parts be used instead, like the caliper? If so, does anyone know the part number?
Any thing anyone wants to add, please do so...
Old Dec 21, 2003 | 12:11 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Stopping power isn't much different from the earlier style PBRs, except the LS1 rotors are thicker. The main difference is the better drum type ebrake.
Yes, any pad for an LS1 can be used. I have Hawk HPS pads. I opted for the solid rotors, but any LS1 slotted or drilled rotors like Eradispeed rotors can be used. LS1 rear caliper braided lines can be used too. Dunno about Vette parts.
Old Dec 21, 2003 | 07:33 AM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
How is the swap? Difficult, not to bad? Also did you go from drum or disc to LS1 brakes? I am not sure if going from discs is easier, seems like it would be...Thanks
Old Dec 21, 2003 | 02:11 PM
Swap is easy. If you have disc already, everything will bolt right up. Drum rears have to be hacked and drilled.
Old Dec 21, 2003 | 05:39 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Killer, I will probably get a disc rearend anyway, then I will change it over. Thanks for the info...
Old Dec 22, 2003 | 08:11 AM
Ram Air TTA's Avatar
Car: 1989 Turbo Trans Am
Engine: 3.8L Turbo V6
Transmission: 2004r
Guys,
What about swapping the LS1 brakes to a 9 bolt rear???Has anybody done this and how difficult?? Also does anyone know if the axle flanges are the same as a ten bolt (bolt spacing) Thanks
Old Dec 22, 2003 | 08:21 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
here is the link to the drum/ls1 swap info.
http://members.fbody.com/86firebird/ls1/ls1brakes.htm
Old Dec 22, 2003 | 04:53 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
I read the tech article a while ago. When I reread it the other day I noticed that it didn't say anything about swapping from stock discs. That is why I posted. I was thinking it may be easier to swap from discs to the LS1 brakes. Guess I was right. Thanks for all the info guys...
Frozer!!!
Jan 19, 2024 04:55 PM
sailtexas186548
Jan 19, 2016 12:21 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
86White_T/A305
Aug 17, 2015 12:16 AM
sailtexas186548
Brakes
Aug 13, 2015 11:47 AM
