Do I have 1LE brakes?
Old Jul 29, 2004 | 03:01 AM
  #51
Spdfrk1990's Avatar
There is a new SS ceramix not as good as the CMX but compareable to all the other top brands.
SS7300X
Old Jul 29, 2004 | 09:01 AM
  #52
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
$51.79 calipers ($50 core charge)
$37.79 raybestos rotor
from rockauto.com
i got autospecialy pads from summit for my ls1 swap, and so far they seem to be a good pad for the price.
Old Jul 30, 2004 | 02:16 AM
  #53
robertg's Avatar
Car: 2000 astro
Engine: 4.3
Transmission: A4
Axle/Gears: 7.5 with 3.42 gears
SS7300X
yeah, completely forgot about that line. i just started stocking it.
it carries the same 2 year warranty as the regular safety stop, but has a ceramic formulation to minimize dusting, and handle heat much better than organic or metallic pads.
consider it the "poor man's ceramic pad."
thanks
Old Jul 30, 2004 | 09:25 AM
  #54
Spdfrk1990's Avatar
Do you think its ok to use ceramix with drilled and slotted rotors. I know your not suppose to unless your rotors are turned cause they wont form to the uneveness.
Old Jul 30, 2004 | 09:26 AM
  #55
Spdfrk1990's Avatar
I could list all the 1le numbers from napa if you want lol.
Old Jul 30, 2004 | 04:50 PM
  #56
Alexcoqui's Avatar
Car: Trans Am "GTA"
I bought sloted rotors, So ceramix shouldn be used?
Old Jul 30, 2004 | 05:35 PM
  #57
Spdfrk1990's Avatar
I dunno i know your not suppose to use them with stock rotors that are un even. I think they would be ok tho ceramix arent made to take alot of heat those so dont do any road racin.
Old Jul 30, 2004 | 05:58 PM
  #58
Alexcoqui's Avatar
Car: Trans Am "GTA"
Im getting the AE7300M's.
Old Jul 30, 2004 | 06:32 PM
  #59
Spdfrk1990's Avatar
Thats a good pad but you will get some dust make sure too shim it and use the silicone on the shim.
Old Jul 30, 2004 | 07:17 PM
  #60
Alexcoqui's Avatar
Car: Trans Am "GTA"
Sorry for the dumb question, but what do you mean by:
"make sure too shim it and use the silicone on the shim."
& another thing... at some point in here you mention that I should get new bearings. can you explain why?
Old Jul 30, 2004 | 07:19 PM
  #61
Spdfrk1990's Avatar
If your gettin new rotors figured it would be a good thing so you have them with new races. Also shims keep the pads from wearin to the piston which will cause them to squeek.
Old Jul 31, 2004 | 06:09 PM
  #62
Alexcoqui's Avatar
Car: Trans Am "GTA"
OK, can you explain how to do the shims on the pads, Where do I get the shims & what size. I guess the silicone is so that the shims will stay in place right?
Old Jul 31, 2004 | 06:16 PM
  #63
FruityOne's Avatar
Car: 1989 TransAm GTA
Engine: One sweet modified 355 TPI.
Transmission: The kind that shifts....
Lifetime warrenty....... Never buy pads again!
Old Jul 31, 2004 | 08:09 PM
  #64
Spdfrk1990's Avatar
They usually come with shims just stick it on the back of the pad on the piston side. Then just put a light coat of silicone on it.
Old Aug 1, 2004 | 03:59 PM
  #65
Alexcoqui's Avatar
Car: Trans Am "GTA"
Thanks Spdfrk1990.
just back from buying the pads & bearings & after opening the box is now obious what you ment.
I whent for the CMX7300 because of what you guys have been telling me about dust. Let me tell you they look beautiful in the box.
Old Aug 1, 2004 | 04:53 PM
  #66
Spdfrk1990's Avatar
Oh yes they do i been eyein a set at work . Ill get it in two weeks when im rdy for em. They are all nicely wraped in plastic and all with the shims and lube lol.
Old Aug 2, 2004 | 08:39 PM
  #67
robertg's Avatar
Car: 2000 astro
Engine: 4.3
Transmission: A4
yeah, they certainly are nice brake pads.
i'll be ready for a set one of these days.
Old Aug 3, 2004 | 10:19 AM
  #68
Alexcoqui's Avatar
Car: Trans Am "GTA"
My brakes geting broken ended up being a good thing.
Other than all the money I wasted.
I had to lern how to change my own brakes now I can add that to my few mechanic skills. Plus since everything was out I fixed my fender wills, grinded all the rust sanded everything, & POR15 the hell out of it. its looking nice down there.
what color you guys think I should paint the calipers? Right now Im undecided between black & red.
Old Aug 3, 2004 | 10:24 AM
  #69
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
cast alum
VHT cast alum.
they'll look like new, and nice.
if you're set on red or black, then black.
Old Aug 3, 2004 | 11:21 AM
  #70
Spdfrk1990's Avatar
I like red like the ZO6 look.
Old Aug 12, 2004 | 10:15 PM
  #71
Alexcoqui's Avatar
Car: Trans Am "GTA"
Ive got my new calipers from Ed, (thanks for everyting Ed).
They are painted & ready to go in. But now that I look at the pictures that I had taken of my old ones. I think that they were installed the wrong way in my car.
Because in the picture that Ed posted in this thread the brake line is in the botom and the bleader on top, as were in my picture the line looks to be on top.
Can someone help me here I dont want to mess it up. Is it even posible to put the cailper in backwords?
Old Aug 13, 2004 | 01:06 AM
  #72
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The hoses attach on the bottom. Someone probably used the wrong hoses and that was the only way they could make them fit.
Old Aug 13, 2004 | 06:04 AM
  #73
Spdfrk1990's Avatar
Woah some1 really messed ur **** up. I dont see how u would get the air out of the caliper with the bleeder on the bottom.
Old Aug 22, 2004 | 01:58 PM
  #74
Alexcoqui's Avatar
Car: Trans Am "GTA"
I took the car out for the first time today. It feels OK not a big diffrence, I guess I was expecting to much. They do feel like they stop a little beter and the bigest improvement is that the car dosnt pull the the side when I slam on the brakes.
Im thinking that the system might need to be blead again. When I press on the brakes the pedal goes in almost half way before I can feel the car stoping. Is this normal? Im not shure what to look for & I also think that it might be all mental, because Im puting to mush atention on the brakes now.
what you guys think?
ps: I will be posting pictures of the brakes soon tey look cool, I think.
Old Aug 22, 2004 | 02:09 PM
  #75
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
check the fluid level, make sure there are no leaks around the banjo bolts, and then bleed again
Old Aug 22, 2004 | 02:39 PM
  #76
Spdfrk1990's Avatar
Exactly you have air in the system or a leak. Possibly crappy hoses is you didnt replace them.
BADNBLK
Convertibles
Sep 21, 2015 07:56 PM
dbrochard
Sep 19, 2015 08:13 PM
Necron
Brakes
Sep 14, 2015 12:45 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
