Do I have 1LE brakes?
Old Jul 22, 2004 | 09:32 AM
Alexcoqui's Avatar
Car: Trans Am "GTA"
My brakes are busted & I took the car to Tire Kingdom.
So the mechanic calls me back & tells me that my car dosnt have the regular brake sistem, that its been altered. Then he calls me back & tells me that he found out that what my car has is a special package that consists on Corvette brakes. Im like what? Do you meen 1LE? But he has no idea. & that has me woried.
I looked at the calipers & here are the numbers.
Front: PBR #4281 444 #4811 893 Made in Autralia.
Back: BTR S #K332-071C 5
NEED HELP!
Old Jul 22, 2004 | 10:41 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Looks like you might....
About the only thing that would be an issue as far as they are concerned, is that the parts will cost alot more than they would otherwise.
What are they planning on replacing?
Old Jul 22, 2004 | 10:43 AM
Spdfrk1990's Avatar
If you have front pbr's and dual piston you have the 1le's
Old Jul 22, 2004 | 10:49 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Get that car away from Tire Kingdom ASAP and talk to us before you pay to have ANY work done on your brakes there. We can help you out and save you a LOT of money.
If they look like this, you have 1LEs:
Ed
vsixtoy's Avatar
Car: '87 Cam RS V6
Engine: Top Secret
Transmission: DYT700R4 custom inerts and conv.
Re: Do I have 1LE brakes?
NEED HELP!
Call him back and tell him he should be the expert and know that the car has the "Performance Package" brake system from GM as a factory option. This is very common for these cars and if he where the "expert" you trusted to take your car to, then he would know that without you telling him.
Old Jul 22, 2004 | 10:58 AM
Alexcoqui's Avatar
Car: Trans Am "GTA"
I went to get my car back & is safe at home. Dont want to do nothing in a hurry.
Im going to look at my brakes now to see if they look like the ones on the pic.
thanks for the quick reply.
Old Jul 22, 2004 | 11:00 AM
Alexcoqui's Avatar
Car: Trans Am "GTA"
by the way they say I need new rotors & pads all way round & front calipers.
I knew about the rotors & pads & how can I tell if my calipers are bad?
Old Jul 22, 2004 | 11:05 AM
Alexcoqui's Avatar
Car: Trans Am "GTA"
Ed, the picture you showd me looks like my front brakes but the back ones are smaller.
so if I have 1le suspentin that meens the previous owner put them on. Right?
Old Jul 22, 2004 | 04:21 PM
ebmiller88's Avatar
The rears arent' gonna look like the fronts, they'll look like this. Click the link in my sig for more pics and stuff:
Old Jul 22, 2004 | 04:28 PM
DeWynter's Avatar
The rear brakes are the same as all 89 and on disks. Aluminum calipers with I think 11.7 inch rotors.
Old Jul 22, 2004 | 04:56 PM
Alexcoqui's Avatar
Car: Trans Am "GTA"
So how do I have 1LEs on my car, they didnt come on the 305s right?
& where would be the best place to buy new parts for them?
I wanted to get the sloted rotors.
Old Jul 22, 2004 | 05:00 PM
Alexcoqui's Avatar
Car: Trans Am "GTA"
what about braded lines who has the best quality ones.
And do they need to be special 1LE lines or any 28-92 braded lines will fit?
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Sure they did. You'll need lines specifically for 1LE.
Old Jul 22, 2004 | 05:21 PM
Spdfrk1990's Avatar
Yeh there were 305 5-speed 1le cars. Couldnt you order the brake package from the factory? Anyway for the hell of it check you drive shaft see if it is aluminum. If so its prolly junk so you can send it to me if you want ill trade.
Old Jul 22, 2004 | 05:26 PM
Alexcoqui's Avatar
Car: Trans Am "GTA"
shure just send me your carbonfiber one.
Old Jul 22, 2004 | 05:28 PM
Alexcoqui's Avatar
Car: Trans Am "GTA"
OK so you could get 1LE with 305, but wasnt it an option where you had to get ac delete & some other junk?
Old Jul 22, 2004 | 05:30 PM
Alexcoqui's Avatar
Car: Trans Am "GTA"
By the way can someone send me a pic. of the regular front brake setup?
I want to see if there is a big difrence between those & the 1LEs.
Old Jul 22, 2004 | 05:31 PM
Spdfrk1990's Avatar
The only 1le's that i know of that still had ac were the rs cop cars.
Old Jul 22, 2004 | 05:41 PM
Alexcoqui's Avatar
Car: Trans Am "GTA"
So that meens that if I have the 1LE package in my car is not factory?
But most important. how can I be 100% that those brakes are 1LEs.
I need to fixem as soon as posible. My GTA is my daily driver.
Old Jul 22, 2004 | 05:42 PM
Spdfrk1990's Avatar
If they look like the ones posted they are.
Old Jul 22, 2004 | 05:50 PM
Alexcoqui's Avatar
Car: Trans Am "GTA"
So where is the best place to get parts for them.
Old Jul 22, 2004 | 05:54 PM
Spdfrk1990's Avatar
Any auto part store has them just make sure you tell them you have the performance package thats how they list it usually not 1le.
Old Jul 22, 2004 | 06:17 PM
Alexcoqui's Avatar
Car: Trans Am "GTA"
OK, thanks for all the info. One more thing, who sells the 1LE sloted rotors.
Old Jul 22, 2004 | 06:18 PM
Spdfrk1990's Avatar
Im getting mine from Napa 200 for all 4 but of course i work there .
Old Jul 22, 2004 | 06:20 PM
Alexcoqui's Avatar
Car: Trans Am "GTA"
how much are you saving?
Old Jul 22, 2004 | 06:36 PM
Spdfrk1990's Avatar
I think around 50 dollars or a lil more. Goto www.napaautoparts.com
Its w/ performance package and hi-performance rotor its drilled and slotted.
Old Jul 22, 2004 | 06:38 PM
Spdfrk1990's Avatar
Here one of the front sides.1LE Rotor and PN#
Old Jul 22, 2004 | 11:40 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
If you want to know if your car is a true 1LE or a converted 1LE check the RPO codes
Old Jul 23, 2004 | 09:30 AM
red87iroc's Avatar
Car: No F-Body Currently :(
Engine: none
Transmission: none
Axle/Gears: still...none...(ugh)
Alex,
Take a ruler (tape measure) and measure across the widest part of your rotor. If I recall correctly (and I will be corrected if not), standard rotors are apporximately 11"+ in diameter, and 1LE rotors are approximately 12"+ in diameter.
Also, if you are able to remove the rotors, take one of the fronts and one of the rears to the parts store when you go to get new rotors, so you can be sure your new rotors are the same diameter as the originals, and the rest of the parts you are getting are also correct. It would also be wise to take a set of your old front and rear pads also so you can be sure those are correct as well. Trust me, you parts counterperson will be glad you did this.
The most common thing that occurs when calipers go bad is that they hang up, which causes the inside brake pad to wear faster than the outside one. Look at the brake pads on the car now, and see if they are all the same thickness. If they are, you calipers are probably okay unless the boot/seal is torn, or if they are leaking fluid. When you install new pads/rotors, you should install new pins(bolts) and o-rings as well.
Old Jul 23, 2004 | 11:38 AM
Alexcoqui's Avatar
Car: Trans Am "GTA"
Red, thanks for all that good info. I tried measuring the rotors but I cant get an eaven number. Is somewhat more than 11 and less than 12 inches.
About the calipers, my front rotors are eaten from the back so that means my calipers are mest up like you said.
& Im positive that they are 1LEs because Ive been looking at regular front calipers & they look noting like mine. Mine have the 2 pistons like the one ed shoud me. and mine are way biger than what Ive seen around. In fact my back calipers look like the front ones from the regular setup.
About my RPO code sheet, what hapend is that when I got the car the center console was all nasty so I took it out & put a new one from Year One & my wife threw the old one away witout asking me. Since I didnt know a lot about my car at the time I never got to understand what it said when I had it & now that I do its gone.
I gues I could call Pontiac Historic Services or whaterver is called to get them, but my car couldnt be a real 1LE. Its got A/C & its a 305 automatic, I dont think it would had hapened.
Old Jul 23, 2004 | 11:45 AM
Spdfrk1990's Avatar
Yeh 1LE's are almost 12 but not quite. Heres mine they'll soom be red with the drilled and slotted rotors and earls lines.
Old Jul 23, 2004 | 11:51 AM
Alexcoqui's Avatar
Car: Trans Am "GTA"
Let me ask you something how come your rotors aint all oxidated, can you paint them & is there a special paint to do these.
Old Jul 23, 2004 | 11:57 AM
Spdfrk1990's Avatar
I painted them with aluminum hi heat header paint. Paint everywhere the pads dont hit and dont paint where the bearings go of course.
Old Jul 23, 2004 | 12:03 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
If your car had been a police car with the B4C package, it could have A/C and 1LE.
Old Jul 23, 2004 | 12:11 PM
Spdfrk1990's Avatar
But doesnt he had a GTA i never heard of any b4c GTA's .
Old Jul 23, 2004 | 06:21 PM
Alexcoqui's Avatar
Car: Trans Am "GTA"
Damn, a GTA cop car. That was a cool cop.
Old Jul 23, 2004 | 06:24 PM
Alexcoqui's Avatar
Car: Trans Am "GTA"
Spdfrk1990,
Does Napa has the 1LE claipers.
Old Jul 23, 2004 | 07:02 PM
Spdfrk1990's Avatar
Yes they do
Old Jul 23, 2004 | 08:12 PM
ebmiller88's Avatar
Alex, if you need another set of 1LE calipers, get in touch with me and we can work something out...I have a brand new set in the shop. See what prices you get and then contact me, glad to help.
Ed
Old Jul 23, 2004 | 08:13 PM
Alexcoqui's Avatar
Car: Trans Am "GTA"
Cool!
Hey Spdfrk1990,
thanks for all your help.
Old Jul 23, 2004 | 08:25 PM
Spdfrk1990's Avatar
Anytime yeh ide call around tho and see who has the best prices.
Old Jul 23, 2004 | 08:35 PM
  #42
Alexcoqui's Avatar
Car: Trans Am "GTA"
Ed,
Let me know how mush you want for both of them, those are the only components I need to finish this new project.
You know how you told me about those rotors that I posted, well I kind of bought them before reading your reply. & yes now that i think about it you might be righr, if it sounds to good to be true...
But whats done its done. & as long as they las for a couple of month. till I get to fill my pockets some more.
For now I just want to get my car on the road again. You know I had just finished puting the intake back on the engine. I ported & polished from the intake manifold to de plenum. It sound awesome!!!!! but thats all I know.
Old Jul 24, 2004 | 03:57 AM
  #43
ebmiller88's Avatar
Sent you a PM, Alex.
Ed
Old Jul 26, 2004 | 05:18 PM
  #44
Alexcoqui's Avatar
Car: Trans Am "GTA"
Heres a pic. of the front brakes for you guys to see.
Old Jul 26, 2004 | 05:20 PM
  #45
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Those are 1LEs alright.
Old Jul 26, 2004 | 05:21 PM
  #46
ebmiller88's Avatar
Yep!
Ed
Old Jul 26, 2004 | 05:24 PM
  #47
Spdfrk1990's Avatar
Yup ide get new calipers,ceramix pads and new rotors and bearings. Napa and timiken or however u spell it both use Bearing 3 & 6 at napa its br3 & br6. The seals are the same if you want the earls Steel braided hoses goto Spohn they are 95 for all 5 hoses.
Old Jul 26, 2004 | 06:00 PM
  #48
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
I wouldn't get ceramix pads, they don't work well untill they heat up.
Old Jul 26, 2004 | 06:16 PM
  #49
Spdfrk1990's Avatar
Thats wrong maybe if you use cheap ceramix. Napa makes real good ceramix and they work great. Shortest stopping distance of any autostore pads.
Old Jul 29, 2004 | 12:39 AM
  #50
robertg's Avatar
Car: 2000 astro
Engine: 4.3
Transmission: A4
Axle/Gears: 7.5 with 3.42 gears
alex.....
here's a couple napa part numbers for you for brake pads. these are for front pads. please note that prices may vary. these prices are from napaonline.com
CMX7300 - cost you $129. these are the ceramix pads, best thing napa has. minimal to no dusting. lifetime guarantee.
AE7300M - cost you $129. metallic pad. good quiet braking with a lifetime guarantee.
SS7300M - cost $79.99. Mid-grade metallic pad. carries a 2 year warranty.
TS7300M - cost $19.99. Bare economy brake pad. carries a 1 year warranty.
i myself would go with the AE or the SS pads.
best of luck.
