84 T/A brakes
Old Dec 15, 2004 | 08:52 PM
FndmntlsOfPimpn's Avatar
Car: 87 Formula
Engine: 350 tpi
Axle/Gears: Stock 9 bolt
84 T/A brakes
ok heres the deal kids,
Im buying a rearend from a 84 T/A for $150 but i need calipers and rotors what should i put on there jus stock parts if so can i get them new and about how much $ ? or what kinds of other clipers will either bolt up or bolt up with minimal mods? and prices please im tryin to dertimne how much ima need to get my car done this winter
Kevin
Old Dec 15, 2004 | 10:42 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Transmission: TH350C
Axle/Gears: 3:23
The early iron calipers had a lot of problems. If you have to replace them look into installing the aluminum ones - post 1987 I think.
Old Dec 16, 2004 | 06:47 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
If you have to replace the brakes go to the '89-97 PBR rear brakes. They give you a larger rotor and an aluminum caliper. All you'd need is the brakes and the 10 bolt backing plates for the rearend you will get. If looking used, go to www.tacreationsusa.com. Their rear brakes are $150 used. If you want a new kit, they're out there for $600 or so, Baer is $800 for the same thing.
http://www.tacreationsusa.com/suspensi.htm
Ed
Old Dec 16, 2004 | 08:52 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
If you should decide to go with Ed's suggestion, check the following link:
https://www.thirdgen.org/techbb2/sho...hreadid=249098
JamesC
Old Dec 16, 2004 | 09:54 AM
ebmiller88's Avatar
Yes, that's a nice setup he has..
Ed
Old Dec 17, 2004 | 01:37 PM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
Early rear disc calipers are around $80 each not including the core charge. Although they are commonly labeled as having problems if you regularly use the hand brake you shouldn't have any problems. If your car has drum brakes you'll need to install rear disc hand brake cables. These are still available from GM and only about $25 each.
Old Dec 17, 2004 | 01:43 PM
ebmiller88's Avatar
That's the problem...no one does, and if he has to replace the calipers anyway why not upgrade to a system that is proven to work regularly?
GM has discontinued these cables. You can get them at Napa though. An aftermarket piece but still pretty good at $20 each.
Ed
Old Dec 17, 2004 | 02:36 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Axle/Gears: 3:23
I've had my car since 86 - using the handbrake didn't help much. If you're changing them anyway might as well install the PBRs if you can.
Old Dec 17, 2004 | 02:37 PM
Dens71TA's Avatar
Ed [/B]
The 83-88 rear disc cables are still available(which is what I was refering to above) I just ordered some from my Pontiac dealer last month.
Old Dec 17, 2004 | 02:52 PM
JamesC's Avatar
I've since swapped in PBR's (check the above link), but in advance of that, the old iron calipers were rebuilt with a GM kit of some sort that cured my ills. I used the handbrake religiously and never had another problem. I wouldn't return to the old style, however .
JamesC
BADNBLK
Convertibles
Sep 21, 2015 07:56 PM
dbrochard
Sep 19, 2015 08:13 PM
scotrans am
Sep 5, 2015 04:26 AM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
