my brakes are out......need help
Old Dec 22, 2004 | 07:47 PM
90tbi305's Avatar
Car: 1990 350 tbi l98,
Engine: 5.7 tbi
Transmission: t5
Well i was getting of the high way about 30 minutes ago and when i went to press the brake it just went all the way down. I have no idea what it is. please help..
Old Dec 22, 2004 | 08:19 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
They must have come back or else you would be posting this from HELL!!!!!
If the pedal just feel straight to the floor without warning I would start to think that you have had a terrible fluid leak. Like a wheel cylinder blowing out. Or else I would think a hose or line blew open. If the pedal went to the floor and then you pumped it back up and they worked fine after that I would think its the master cylinder...
Give a little more info about its symtoms and how you got the car to stop...
Old Dec 22, 2004 | 08:33 PM
crazy3rdgen's Avatar
Car: 2002 SS
Engine: Ls1
Axle/Gears: 3:42 posi
yea it sounds like u lost pressure in the lines/line.. i would think a leak aswell..look it all over and check ur brake fluid
Old Dec 23, 2004 | 02:12 PM
Tremo's Avatar
Car: 88 IROC-Z - original owner!
Engine: LB9 with K&Ns, MSD, Foil, Taylor
Transmission: WC T-5
Axle/Gears: BW 9-bolt, 3.45 posi
I see you put on Earl's steel hoses. Maybe something went wrong there and you lost your fluid?
Don't drive the car until this is fixed. Very dangerous.
BADNBLK
Convertibles
Sep 21, 2015 07:56 PM
dbrochard
Sep 19, 2015 08:13 PM
Necron
Brakes
Sep 14, 2015 12:45 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
