Which set of lines will work?
Old Dec 25, 2004 | 03:07 PM
FndmntlsOfPimpn's Avatar
Car: 87 Formula
Engine: 350 tpi
Axle/Gears: Stock 9 bolt
ok im looking for all stainless lines for my 89 camaro its got disc front and a rearend outa a 84 t/a with disc brakes. Which one of these kits will work i was htinkin that it would all be interchangeable from 82-92 am i right or wrong?
Old Dec 26, 2004 | 11:36 PM
Car: 87 Formula
Engine: 350 tpi
bumpety umpety ttt
Old Dec 27, 2004 | 12:23 PM
Motor City Mike's Avatar
Car: '82 Trans Am
Engine: Blown 540 BBC
Transmission: TH475
Axle/Gears: Dana 60, 4.10 w/spool
Since you got an '84 rear end, I would venture to say that #CA1048 is the one you would want. The front brake lines should be all the same.
Since you live in SE Michigan, why don't you just get 'em direct from these guys: Inline Tube.
Old Dec 27, 2004 | 04:17 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
www.finelinesinc.com gotta be less than those prices what catalog is that?
i got rear axle ones for my z at like 38.00 does the entire rear and they look exactly like stock all the right bends ect...
Jeff
Old Dec 27, 2004 | 07:31 PM
Car: 87 Formula
Engine: 350 tpi
thats for a full brake line kit from one end to the other seems pretty reasonable thats outa the classic tube catolog i looked at finelines website but it was ahrd to follow and couldent tell what the did/didnt have
Old Dec 27, 2004 | 10:34 PM
JeffW's Avatar
Engine: 305 tpi LB9
http://finelinesinc.com/catalog/prod...oducts_id=3002
rear line 35.00
fronts depending on design
http://finelinesinc.com/catalog/prod...oducts_id=3136
90.00
frt to rear line
http://finelinesinc.com/catalog/prod...oducts_id=3036
70.00
looks like 195 for all new stainless from finelines.
jeff
Old Dec 27, 2004 | 10:36 PM
JeffW's Avatar
Engine: 305 tpi LB9
problem your gonna find with the kit you posted is with the diffrent rear your lines are a little diffrent from the 84 - 89 years. how diffrent i'm not sure.
jeff
Frozer!!!
Jan 19, 2024 04:55 PM
specialized
Jun 18, 2022 09:26 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
