Best brake librication
Old Dec 27, 2004 | 12:21 AM
Meatman's Avatar
Car: 1988 Formula
Engine: 355
Transmission: 6 speed
Whats the best grease to use on the sliders on LS1 front and rear brakes? Wondering whats best and what everyone uses.
Old Dec 27, 2004 | 03:59 AM
oil pan 4's Avatar
Car: 89 Firebird
I spred on a layer of copper based anti seize.
But now I got a can of Molybendium Disulfide dry lube spary and will most likely use that now.
I never did do any LS1 breaks, just disk breaks in general.
Old Dec 27, 2004 | 06:36 AM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
sylglide, most parts stores carry it, silicone based lube unaffected by normal brake heat.
Old Dec 27, 2004 | 11:38 AM
Motor City Mike's Avatar
Car: '82 Trans Am
Engine: Blown 540 BBC
Transmission: TH475
Axle/Gears: Dana 60, 4.10 w/spool
Silicone grease on the floater pins, copper grease between the caliper and knuckle/caliper bracket.
Old Dec 27, 2004 | 02:09 PM
OneBadZ4U's Avatar
Car: '86 Iroc, '87 Iroc Vert
Engine: 350 TPI, 305 TPI
Transmission: T5 in both
Axle/Gears: 3.73, 3.45 both LSD's
With a name like Meatman, I'd have to say use KY Lubricant.
Sorry, Couldn't resist. Seriously, we use Raybestos Silicone Brake Lubricant, Part#DBL-2, on caliper slides.
Old Dec 27, 2004 | 02:22 PM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
Would synthetic wheel bearing grease work? Just curious because I'm going to grease the slider pins and everything one of these days and was curious if that stuff would work.
Old Dec 27, 2004 | 02:28 PM
Car: '82 Trans Am
Transmission: TH475
Not really sure. I like to use the silicone grease because it won't cause the rubber pieces to swell up, and it doesn't get thick in the cold weather.
Old Dec 27, 2004 | 06:30 PM
oil pan 4's Avatar
Car: 89 Firebird
If it heats up to much the grease could end up where you don't want it.
Old Dec 28, 2004 | 04:17 PM
nape's Avatar
Car: American Iron Firebird
Engine: The little 305 that could.
Transmission: Richmond T-10
Axle/Gears: Floater 9" - 3.64 gears
I've always used chassis moly grease on them.
Probably not the best solution, but it will at least keep rust at bay for a while.
Old Dec 28, 2004 | 11:45 PM
Car: '82 Trans Am
Transmission: TH475
This is also a key reason to use copper grease between the caliper and bracket. It is very thick, and helps to transfer the heat - use it sparingly though. The silicone grease in the floater pins is sealed off, and isn't an issue.
BADNBLK
Convertibles
Sep 21, 2015 07:56 PM
dbrochard
Sep 19, 2015 08:13 PM
Necron
Brakes
Sep 14, 2015 12:45 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
