Master cylinder cap problem!!
Old Jan 4, 2005 | 11:45 AM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
Ok well i was driving and i slamed on the brakes just to see how good they would catch and after i did that i saw smoke coming from the engine bay so i open my hood and the brake fuild was all over my exhaust manifold on the driver side. i replaced that stupid seal on the master cap where you add more fuild.. all the time it squrits out like nothing. what should i do?
Old Jan 4, 2005 | 12:35 PM
Benm109's Avatar
Car: 1991 Chevy Camaro
Engine: 305 TBI
A couple of questions, when you put the cap back on, how do you do it (I know that sounds weird)? Do you put the seal on the cap, and then put the cap on the master cylinder, or do you put the seal on the master cylinder, and then install the cap?
Where did you get the replacement seal, at an auto parts store or the dealership? Are you sure that it's a direct replacement, and is the same dimensionally as the old one?
Old Jan 4, 2005 | 02:26 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
hey thanks for the reply bro. i put the seal on first then the cap. i went to a parts store and got one there!! looked the same so i got it and it fits. i think that was a poor make by chevy. or is it that im just doing it wrong?
Old Jan 4, 2005 | 05:57 PM
Benm109's Avatar
Engine: 305 TBI
So you're saying you put the seal/gasket on the master cylinder first, and then put the cap on?
If so, try installing it the other way. Put the seal/gasket on the cap first, and then put the cap on. See if fluid comes out then.
Old Jan 4, 2005 | 06:17 PM
CaysE's Avatar
Trying to seal the cap with the gasket on the cylinder can collapse the gasket, leaving a leak area. You have to put the gasket on the cover first, put the cap on and make sure all four tabs snap onto the reservoir.
Old Jan 4, 2005 | 08:59 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
thanks guys. thats probaly why it kept leaking. ill try that.
25thannivZ28
Aftermarket Product Review
Jan 2, 2016 05:41 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
redmaroz
Aug 16, 2015 11:40 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
