Right front brake caliper is locked up,How do i fix this?
Old Jan 6, 2005 | 12:32 AM
firebird305's Avatar
My 82 Firebird has been sitting for awile,And when i went to drive it about a week ago,I noticed the car going slower and slower on my way back to the house,And i started smelling the brakes from all the heat build-up.By the time i got back to the house,The front right brake was on fire! I put out the fire,But now i was wondering what has to be done to unlock the front brake,Does anyone have any ideas? Thanks for the help.
Old Jan 6, 2005 | 06:09 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Go to a parts store and get a rebuilt one, they're about $15 with a $10 core...easy fix.
Ed
Old Jan 8, 2005 | 10:49 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
don't rule out a internally collapsed brake hose either....
Old Jan 8, 2005 | 10:59 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
How true!!!!!!!!!!!!!
Old Jan 11, 2005 | 08:35 PM
myvmax1's Avatar
Car: 91RS, 91RS
Engine: 305TBI, 3.1MP
Transmission: WCT5, TH700
I had the same thing happen with my drivers side front caliper. Exceprt no fire. Anyway a replaced the hose and the problem was erased. Since then, both of the front hoses have been replaced with braded stainless pieces. Excellent brake feel
~Max
Old Jan 12, 2005 | 12:13 PM
Old Jan 12, 2005 | 09:56 PM
Amaroz28's Avatar
Car: Camaro
Engine: 305 tpi
Whats going on? Im new to thirdgen so im not really sure how to post my own questions... but... Im having the same problem it just started today on my 91z but I replaced both front calipers, and the right one is still stuck, mine didnt catch on fire but i can smell it really bad, and the rim and everything is really hot. Im not sure what is going on, and need to get it fixed so if you find anything out can you reply to me or email me at amaroz28@aol? thanks and good luck
Old Jan 12, 2005 | 10:22 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
What they are talking about Amaroz28 is the flexible brake hose being defective and causing the problem that you and many others (including myself) have experienced. The hoses will get old and collapse internally and block fluid from getting to the brake caliphers or will trap fluid in them and not release the brakes. On the outside the flexible hoses will look fine and be clogged on the inside. Mine happened while doing 65 MPH on a country road, touched the brakes and car did an abrupt 90 degree turn to the left. fortunately for me the road was wide and no traffic at the time.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
