EBC or Hawk?
Old Jan 14, 2005 | 08:06 PM
PaveTim's Avatar
Car: 1991 Z-28
Engine: 350 SBC
Transmission: Probuilt 700R-4
EBC or Hawk?
I am looking into either the EBC greenstuff pads or the Hawk pads which do you prefer. I just have new rotors and reman calipers, stainless braided lines. Nothing special.
Old Jan 14, 2005 | 09:14 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Skip the High priced so called performance pads and just Buy PF z-rated pads and get the same or better results. Also No brake dust with the z-rated pads.
Old Jan 15, 2005 | 12:36 AM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
i got the hawks pads on my car with pretty new rotors (1 yr old), rebuilt calipers and stainless lines and it stops nicely. ive had the pads on the car for ruffly 6-8 months and no problems with squeeling or anything. stops alot better then before. but thatswhat i can remeber , i have driven the car since late oct. early nov. alot to remember. last time i drove it was dec. 5th and thats when my alternator died
Old Jan 15, 2005 | 02:04 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Although the EBCs stop like crazy, they dust like hell. I'd go with another pad.
Ed
Old Jan 15, 2005 | 09:30 PM
semiller26's Avatar
Car: 1986 Trans Am
ill second the dusting like hell. not that i don't like washing my car. but boy was i dissapointed with them.
Old Jan 17, 2005 | 06:40 AM
ebmiller88's Avatar
I bought them for the low dusting claim. This is from Tire Rack.com:
"As standard brake pads wear, brake dust is released as the friction material carbonizes at temperatures found in everyday braking. EBC Greenstuff brake pads are formulated to run cleaner because they resist carbonizing until over 1000° Fahrenheit, so in normal street driving, dusting is reduced."
I'll try and get out this week and take a pic of my front wheels...it's rediculous.
Ed
Old Jan 18, 2005 | 06:30 PM
slowTA's Avatar
Car: '88 Formula
Transmission: T-5... in need of slight rebuild
I've had both the Performance Friction Z rated pads and Hawk HP+. I like the Hawks MUCH better, both give off a 'fair' amount of dust but the Hawks actually work when they're cold. For a daily driven car I would get the Hawk HPS instead. I've also heard that the EBC don't last all that long for aggressive driving, but for normal street driving they last OK at best.
Old Jan 20, 2005 | 08:20 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
I've been happy with my Hawk HPS pads. They stop much better when cold, unlike my old Performace Friction non-z-rated pads.
No noise, not too bad on the dusting. Will be trying HP+ on my next pad change.
Old Jan 20, 2005 | 08:26 PM
slowTA's Avatar
Car: '88 Formula
Thats good to know that the HPS pads work nice when cold. My non Z rated performance friction pads left me hanging on my Malibu. Hawk didn't make pads for it when I needed them and I think they're making them now.
Old Jan 20, 2005 | 11:16 PM
RTFC's Avatar
Car: Agood2.8,
Engine: V6rsr,
Transmission: Afrikingoodtime
Best strret pads money can buy- Stillen.com
Perf friction are terrible. They have no initial bite- you have to lay on them before they come on. EBC's are not much better. I have never tried the Hawks but have run Stillen pads on all of my cars for years now. Just use a set of Perf friction recently in a pinch, (Stillen was temp out of stock for a few days on the pads I needed) so a put some Perf friction on and had them right back off in about 1 week because they scared the crap out of me after being used to the Stillen pads for so long.
Vsix
Old Jan 20, 2005 | 11:24 PM
RTFC's Avatar
Car: Agood2.8,
Engine: V6rsr,
10.5" iron delco morraine "front" and/or "rear" pads- # D154HD
http://stillen.com/brakepros_detail....id=8680&page=1
1LE (PBR)alum dual piston calipers "fronts"- # D412HD
http://stillen.com/brakepros_detail....id=8846&page=1
1LE (PBR) "rears"- # D413HD
http://stillen.com/brakepros_detail....id=8850&page=1
Old Jan 21, 2005 | 01:07 AM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
Oooh! Only $40 for LS1 rear pads! Yay! How are those for dusting? Would they make a 10.5" car actually brake decently? I might not have enough money to do my C4HD upgrade anymore with all the other stuff I have to take care of..
Old Jan 21, 2005 | 06:12 PM
pvt num 11's Avatar
Car: 1989 TTA
Engine: LC2
Transmission: Worn-out 200R4
Axle/Gears: BW 9-bolt, 3.27's
Dean,
I was thinking about the HPS for my rears for now. How would you rate those for normal street driving? I was going to get the fronts re-done in about four-to-six months.
Old Jan 21, 2005 | 06:50 PM
BretD 88GTA's Avatar
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
Ed
Funny, my EBC pads actually dust less. I used to use the PF pads and they would turn my wheels black. The EBC's are definitely better based on my experience. YMMV.
Old Jan 21, 2005 | 07:11 PM
RTFC's Avatar
Car: Agood2.8,
Engine: V6rsr,
Originally posted by pvt num 11
Dean,
HPS-?
Stillen metal matrix- 10 (scale 1-10) for street use.
EBC-8
Perf friction-5
stock pad- 1
I run Stillen pads on every car I own. I just swapped the Camaro to Wilwoods with the new setups but I need to research to see if Stillen makes pads that will fit my Wilwood calipers- If so then I am buying them.
Old Jan 22, 2005 | 03:48 AM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
I run the EBC greenstuffs front and back and find the performance great from cold and low fade with hard running. The dust is heavier than I expected from what I had read up on about these so thats annoying. The dust is more grey than black but it is steady and does cover my wheels almost as fast as OEM metallics. I have yet to find any pad that does not coat the weels with dust in short order so if anyone finds a winner please let us know. Aside from the dust the EBC's are great street/ mild track pads.
Old Jan 22, 2005 | 02:59 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
I have the hawks on my car right now
seems to dust quite a bit more then any other pads on any of my others cars that I have owned
but thing is all the other cars I owned had stock style pads these are the first perfoamnce style pads
thoughas far as bit when cold......... left me really handing at that first stop sign but then again that was only like 300 ft from my house and so no time to warm up at all. after that though they where fine
Old Feb 20, 2006 | 05:46 PM
Craig84Z's Avatar
Car: 1984 Camaro Z28
Engine: Blueprint 383
FYI - I just called Stillen about front brake pads for a 98-02 Camaro Z28 and they don't carry them anymore. They still have them for the rear brakes though.
Linson
Oct 24, 2025 02:00 PM
Fronzizzle
Feb 9, 2017 09:31 AM
CAMAROBEAV
European Region
Nov 18, 2015 06:41 AM
jaridjohn
Oct 5, 2015 07:01 AM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
