Please post procedure and tips about changing Master cylinder
Old Feb 11, 2005 | 07:28 AM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
I will be swapping out my stock master cylinder for the 1LE unit (J50 master cylinder). Some time ago, I upgraded to the 1LE front brakes from SSBrakes. I have never changed a master cylinder before, I would appreciate some help.
TIA
Old Feb 11, 2005 | 08:48 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
It's actually prety easy. I'd suggest emptying as much fluid from the reservoir as you can before you take it out, use a turkey baster or something like that. Loosen the two brake line nuts coming off the side and use flare nut wrenches to prevent rounding the nuts off. Those things are on there tight. The sizes are 12-14mm IIRC for the lines. Then all you need to do is remove the 2 nuts that hold the master onto the vacuum booster with a 15mm socket and it comes right off. Install is done in the reverse order, then bleed the heck out of it.
Ed
Old Feb 11, 2005 | 09:34 AM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Thanks for the reply,,, I thought that it was much more involved.
The hardest thing is going to bleed the system. I will need to get help from the wife and she is not good on helping. (Maybe I can train the new puppy.)
Old Feb 14, 2005 | 03:44 PM
BretD 88GTA's Avatar
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
You may already have a J50 MC on the car. If the MC has been changed at any point in time, odds are it is a J50. It became the standard replacement MC starting in '91, IIRC.
By '91, the J65 was history and all F-bodies got the J50 from the factory.
Old Feb 20, 2005 | 08:18 PM
Nocturnall's Avatar
Car: 91 Firebird
Engine: 191ci 6cyl
woohoo less work for me when I get my new brakes in.
Old Feb 20, 2005 | 10:54 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
https://www.thirdgen.org/techbb2/sho...hreadid=278107
25thannivZ28
Aftermarket Product Review
Jan 2, 2016 05:41 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
87 camaro iroc
Aug 20, 2015 07:47 AM
redmaroz
Aug 16, 2015 11:40 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
