Baer Brakes underneath 16x8" Formula wheel.
Car: '88 Firebird Formula
Engine: 360hp/417ft. lb. 350
Transmission: Pro-Built Street/Strip 700R4
I tried searching and couldn't really find a conclusive answer because most questions regarding brake upgrades seem to be with regard to Camaro wheel clearance.
Anyways, I have an '88 Formula and I need to get rid of the stock brakes in a real bad way. My questions are thus:
1) Will the Baer Sport system (PBR 2 Piston, 12" x 1.10" Rotors) fit underneath the front wheels with no clearance issues?
2) Any clearance issues with the rear Touring system (PBR Single Piston, 12" x .81" Rotors)?
I don't have the car to print up the template and check, it's on the other side of the state because I don't trust it driving around in heavy Tampa, FL traffic.
I spoke with David at Thunder Racing and he said the kits come complete with everything, sans master cylinder. Do you need to upgrade master cylinder with the swap and should the front and rear systems each have their own master cylinder?
The Baer kit is my best option here because they need to slide on and off and come with all the parts so they can be done within 2 days or so, the work is being performed by my mechanic during business hours.
Any performance difference between the slotted/zinc washed rotors and the plain finish?
Thanks for the advice.
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
bear :)
the bear is a nice kit i did my install in about a day, springs were i bit harder on the front.... but the brakes were cake to do. you may want to order up some new lines to go with that. i had to change my rears to make it all reach with the 9 bolt.
you will also need a prop valve. gm parts direct or go adjustable from bear.
Re: bear :)
Car: 1985 Trans Am
Engine: vee eight
Transmission: auto
Axle/Gears: 4.10 gears
they look cool but i think you could do ls1 brakes for cheaper or even the c4hd brakes for cheaper . Pm ebmiller and he will tell you what will fit.
Street Lethal
Aug 13, 2015 08:28 PM
