85 disk brakes, any good?
Old Jan 9, 2005 | 09:58 PM
firbird's Avatar
I have a chance to pick up a 85 Ta rear end with disk brakes. I have read somewhere don’t know if it is true that there were disk brakes that were equipped on the third gen that were put on the earlier years that were worse then drums them self and was wondering if this was one of them. 85 is the first year of the 7 and 5/8's ring gear correct?
Thanks for your help.
Old Jan 9, 2005 | 10:01 PM
Parrydise7's Avatar
My 1985 has the Delco Moraine iron discs and, while I don't know if they are worse than drums, they are definitely not as good as the PBRs.
Old Jan 10, 2005 | 08:26 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Before I swapped to PBR's, I had the iron version with the rebuild kit. Do a search and you should find the part number of the kit. Afterward I used the e-brake often and never experienced any problems. If I'm not mistake, my 85 IROC has the smaller ring gear.
JamesC
Old Feb 18, 2005 | 09:03 PM
maroguy1's Avatar
Car: 85 iroc & 81 sc
Engine: 357 tpi 350 4bbl
Transmission: 700r4/ richmond 4speed
Axle/Gears: 9 bolt 3.45/3.42 8.5"
88 and new has the 7 5/8 ring gear. 88 up calipers are better but about the same as the 87 older calipers that are up dated.
Old Feb 18, 2005 | 10:45 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
I thought all the 10 bolts were 7 5/8".
Old Feb 19, 2005 | 06:59 AM
maroguy1's Avatar
The older had 7.5 ring gears. 78-87 El caminos Malibus and Monte carlos had the same crappy rear.
Old Feb 19, 2005 | 01:49 PM
18inchboyds's Avatar
Car: 1985 Trans Am
Engine: vee eight
Transmission: auto
Axle/Gears: 4.10 gears
my rear brakes hardly ever worked, they were junk , i had them fixed and they worked for half the summer and then when i took it out of storage after winter they didnt work anymore . They are crappy , it sucks how you have to adjust them with the parking brake.
Old Feb 20, 2005 | 10:12 PM
biff85ta's Avatar
Car: 04 Vette
An 85 rear with rear discs has a good chance of having a 7.75 ring gear or what is known around these boards as a 9 bolt.
Old Feb 21, 2005 | 07:50 AM
Car: 1985 Trans Am
Engine: vee eight
Transmission: auto
thats what mine had and they sucked , those brakes were horrible.
sailtexas186548
Jan 19, 2016 12:21 PM
redmaroz
Aug 16, 2015 11:40 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
