Brake hose compatibility with brake upgrades
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
I just picked up an Earl's stainless steel braided hose kit (front caliper hoses and body-to-rear-axle hose) for a good price and was going to install it one of these days. I was just curious, are these lines compatible with any of the brake upgrades? LS1? C4/C4HD? I'm wanting to go with one of those setups, but was curious if these hoses will work on either of those setups.
Car: 1997 Corvette
Stock for thirdgen, non 1LE. Comes with each front caliper hose and the hose from the body to the rear axle (the one with the T-block on the end). Pn# 28A180
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
It will depend on the overall length of the lines and where the caliper is clocked. The C4s and LS1s put the caliper low around the 4-5 O'clock position, the C5s are around the 2-3 position. Can you measure it for us? I have 2 1LE sets in the shop and I'd like to know how long your lines are. I only recommend the 1LE spec lines for the front up grades but if your lines are long enough, they'll work. Are the caliper ends in block shape or are they the round type fitting?
Ed
Ed
Car: 1997 Corvette
Round type fitting, the braided part is just under 17", and there is about 1/2" at the end of each braided section where it connects to the brake line or caliper end.
The 1LE lines are 22 1/4" overall with the strut mounted brake line bracket fitting right in the middle at 11 1/2", they have the block type banjo caliper fitting. For comparison, I have Russel lines on my RS with C4 HDs and they BARELY fit, I have to take the line out of the strut brake line retainer bracket to get the caliper off. I'd run 1LEs if you have the choice but if they fit you'll be OK. The round banjo fitting will be fine.
Ed
PS: So the 1LE lines have about 5" extra which is good, but remember that 1LE calipers have the brake line fitting on the very bottom of the caliper; all C4s, LS1s, and C5s all have that fitting on the back side of the lower piston.
Ed
Car: '85 Trans Am FAILBIRD
Axle/Gears: 4th gen torsen 3.42
This is a useful thread. I just dropped a LS1 rear in my '84 TA (discs all around orig.), and I'm looking for an Earl's kit. Will be doing C5 fronts next week. From what semiller said, looks like the 1LE kit will work for me, as the PBR rear setup should be about the same as the ls1 rear, right?
Car: 1997 Corvette
Good to know, I may just keep my currnet lines then. I have C4HD rotors laying here on my floor, and the powdercoated calipers with pads are on their way to my house as of later today. That means all I need is the hubs, brackets, and carriers for my C4HD brakes
Car: 88 Iroc-z
Engine: L98 350
does anyone know if ls1 front brake lines will work with the c4 brake up grade? just wondering if it will clip in to the strut and the size is right. i just put and ls1 rear end in so if thay would work i could just get the ls1 ss brake line kit
Ryan
Ryan
Car: Firebird 88
Engine: 406
Transmission: th400
Axle/Gears: 3.50
OK, heres another - Im having rear drums for now, but I will change them dor discs some day.. The question is - if I buy the 4 wheel disc version, will I be able to plug them with drum ones and the "extra" hose will be used after I change them or is it different..?
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
Re: Brake hose compatibility with brake upgrades
I know this is an old thread, but is the proper part number for the 1LE lines Part #: 28A190ERL as shown here? Thanks!
Yes, the 5 piece line set (1LE).
Ed
Ed
Car: 1991 RS Camaro
Alright. Thank you! I'm wanting to get solo bleeders as well, but I can only find them for the fronts. Where could I get a set of them for a 'LT1' rear end? The 89 (90?) to 97 brakes.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
JamesC
Car: 1991 RS Camaro
Thanks for the review. If they are that bad, I'll probably just do it the old fashion way. Maybe I can find a better brand...
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
Night rider327
Sep 2, 2015 04:17 AM
