1LE brakes ??????
Old Mar 10, 2005 | 02:32 AM
doc76239's Avatar
Car: 1989 FIREBIRD FORMULA WS6
Engine: TPI 305
1LE brakes ??????
I want to know what is required to swap 1LE calipers and rotor for the standard front disc brakes on an 89 bird? I need new brakes all the way around. i'm rebuilding my rear 9bolt pbr's. Any info helps. I did a search and was not able to find any thing specific to my swap questions.
Old Mar 10, 2005 | 07:26 AM
DartByU's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Did you read this article from the tech section???
http://www.ws6transam.org/1LEbrake.html
Old Mar 10, 2005 | 12:02 PM
doc76239's Avatar
Engine: TPI 305
Thank you
Thanks DartByU, that is what I was looking for. Another question for any one to answer. What if i was to locate a set of 1LE spindles, and calipers. Then that would make it a bolt up, or are the 1LE spindles and the stock spindles mounted diffrently?
Old Mar 10, 2005 | 03:26 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Bolt up--but the chances of locating true 1LE spindles are about the same as winning the lotto. As you'll note in the above link, the 1LE spindles simply have the 'ears' cut off stock spindles. Many members have completed this mod to include me. If you're interested, you might buy AndyZ28's CD which details the procedure. Ed Miller also has pictures.
JamesC
Old Mar 10, 2005 | 09:44 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
I just did 2 sets of them today...
Ed
Old Mar 11, 2005 | 12:42 AM
doc76239's Avatar
Engine: TPI 305
dam
Does any one sell the modified spindles? I'm short on time to make them my self. Sounds like I might just stick with single piston originals for now. Use semi metalic pads and drilled slotted rotors.
Old Mar 12, 2005 | 03:05 PM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
Get Ed to do your spindles and buy these 1LE calipers I'm trying to unload!
Old Mar 14, 2005 | 07:36 AM
doc76239's Avatar
Engine: TPI 305
Check this out
I just found out YearOne sells the 1LE brake set up, calipers, modified spindles, rotors, caliper bracket, every thing, but spendy. One 1LE caliper is like 400 dollars if I remember right.
Old Mar 14, 2005 | 08:00 AM
Mongoose's Avatar
Car: 90 Formula
I'll sell you a PAIR of the calipers for $250.
Old Mar 18, 2005 | 08:04 PM
Parrydise7's Avatar
I just checked and gmpartsdirect.com still has p/n 18060581 (spindle). I can't remember which side this fits. Unfortunately, the other side, p/n 18060582 didn't come up when I did a search. (I got the part numbers from a Super Chevy article about converting to a 1LE that was printed about two years ago).
What do you think? Order two 18060581 spindles, and try to trade someone for the other spindle?
BADNBLK
Convertibles
Sep 21, 2015 07:56 PM
dbrochard
Sep 19, 2015 08:13 PM
Necron
Brakes
Sep 14, 2015 12:45 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
