Brake problem
Old Mar 15, 2005 | 10:09 PM
NE_Z's Avatar
Car: 1985 Z28
Brake problem
Went to work on my gf's camaro today, been having some brake problems. When you go to press on the brakes it feels ok till you get down further, then the pedal just feels like it releases and goes to the floor.
I checked around the car for fluid leaking and didnt see any. Check the fluid level and it hadnt moved at all. Any ideas on this? not really good with brakes, can change em and thats about it
Old Mar 15, 2005 | 10:26 PM
IROC212's Avatar
Car: 1986 IROC
Engine: 355 Tpi
Axle/Gears: 9 Bolt 3.27
It almost sounds like the Master cylinder is bad. There may be a bad spot inside where the seals on the piston ride. They are super cheap (reman) and fairly easy to do. Just be sure to bench bleed it.
Old Mar 15, 2005 | 10:28 PM
NE_Z's Avatar
Car: 1985 Z28
Thanks for the help. Gonna check into that first thing tomorrow
Old Mar 16, 2005 | 12:59 PM
NE_Z's Avatar
Car: 1985 Z28
Put the new master cylinder in this morning. Works great
ZMWojnar
Brakes
May 12, 2019 10:43 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
overdriv
Aug 20, 2015 03:52 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
