front calipers on rear
Old Apr 4, 2005 | 08:12 PM
NuBird's Avatar
Car: 86 Transmaro, yes I'm for real do a
Engine: 383, 4 bolt block, scat crank, PM r
Transmission: t5 NWC and its holding up behind my
Axle/Gears: 9 bolt aussie, 3.73s from yukon gea
My stupid rachet mechanism J65 rear calipers bout gave me a stroke due to the undue stress of always fooling with them. So i dug out my grinder and employed the use of my bench grinder and put 2 drivers side calipers on the 9 bolt rear and its working fine, had a little trouble getting sone of the old fittings to mate with eachother but I also used front rubber brake lines. i have no e brake but hey I have a manual tranny you may have to use an adj valve depending on your master cylinder. Just a project update HAPPY WRENCHING! oh and say no to **** burners and alternative music...long live camaros and eddie van halen!
Old Apr 4, 2005 | 08:56 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: front calipers on rear
Actually, that's a bad combination.
Old Apr 4, 2005 | 09:09 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
pictures?
Interesting. because Ive thought about doing kinda the same.
C5/Z06 13inch in the rear and the new Z06 14inch up front.
but with all the kits out there for the back its prob not worth the effort to mess with it.
Old Apr 4, 2005 | 09:10 PM
NuBird's Avatar
yeah i know but come to think of It I never had a car where the e brake actually functioned properly, maybe its my beer budget and champagne taste oh tell me what y'all think of this car and see if anything you see is different
Attached Thumbnails front calipers on rear-c-my-documents-my
Old Apr 4, 2005 | 09:25 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Sharp looking car man.
Pic's of the brake swap?
and more info in the car. motor. etc.
looks good.
Old Apr 4, 2005 | 09:37 PM
NuBird's Avatar
thats not my car, but that car has a camaro doghouse and a firebird body, thats what I'm going to do to mine hopefully it will turn out as well. AS for the brake swap, on the bottom of the piston housing there are these bumps cast into them, you have to grind them off to where the housing is round. Then onto the axle housing brackets, you may have to hog them out and make them a little more deeper for the calipers belly to fit through, th key is to get to where the caliper bolts will go in straight without having to force them into position, the rear caliper fittings wont work and don't try to grind them to fit, I used the front rubber hoses and some parts store brake line to go from the T to each caliper, seems to be working good so far, this is the first car i built from scratch and Lemme tell you if you have never done it, do it and if you have never done it, don't do it lol, once you will do it you will understand what i mean
1992rs/ss
Jan 31, 2025 05:10 PM
SiCkRs
Members Camaros
32
Jul 1, 2018 04:53 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
