For anyone who wants to upgrade to 12" rear rotors for their PBR J65 brakes....
Old Apr 16, 2005 | 08:46 AM
drain89's Avatar
Car: 02 WS6 White/Ebony
Axle/Gears: Stock 3.42
ATTENTION: If you have oem drums...disregard this. This is for disc cars only.
I have a strange 12 bolt which uses the small gm pattern housing ends but with a 3.150 bearing. It's called a "Strange" Housing End. It's designed to work with stock 93-97 rear brakes which use the same calipers/ guides as the 89-92 PBR's. Also I'm told that 89-92 and 93-97 rotors interchange. The only difference I understand is a very slight rotor diameter difference. The offset is 2.75".
I'm using Baer 2301012 Eradispeed+ 2 pc. Rotors from an 88-96 Vette which only come in 12" diameter.
I had to order Baer backing plates 6710056 & 6720056 which allow for a 2.5" offset along with four .250" spacers and four bolts that are 5mm longer than stock.
Baer says that they now offer a backing plate that allows for 2.75" offset w/o using the spacers.
The inside diameter of the rotor hat requires the wheel flange of the axle to be 5.90" max. diameter. My Strange axles are 6.240" so I have to have the alxe flange turned down on a lathe. No biggie.
Baer first told me this would not work. Especially Bill there. However after a few calls with Rick and Dutch at Baer, I was able to determine that this was possible to do w/o making a set of custom backing plates.
I know several guys have wanted to upgrade their PBR's to the 2pc Eradispeed rotor. You may have to experiment with spacers/shims to get the caliper offset right, but as long as your wheel flange has at least a 2.5" offset from the backing plate flange...you should be fine. If for some reason, your rear had less than 2.5" offset: you'd have to use a different backing plate than these (if they have one).
I know that if you're considering getting a Moser rear...You can get their 12 bolts with the Strange housing end. They'll accomodate whatever width or brake offset you want also. I assume they can do the same with their 9" rears too. Therefore the above info should also apply. Just be sure to ask for a 5.90" wheel flange dia.
Good Luck!
Dwain
Old Apr 17, 2005 | 01:01 PM
nape's Avatar
Car: American Iron Firebird
Engine: The little 305 that could.
Transmission: Richmond T-10
Axle/Gears: Floater 9" - 3.64 gears
Good info to know.
Do you have the price on these pieces handy? Just wondering how much more I'll have to put into the car.
Old Apr 17, 2005 | 02:11 PM
drain89's Avatar
Tbyrne got me the best prices on a gp. They were still high though.
You can go with one piece rotors also...like EBC and it'll be cheaper. You wouldn't have to upgrade to 12" rears though. The reason I went with the 12" rears is because I wanted the 2pc Eradispeed + rotor and that's the only one they offered.
Frozer!!!
Jan 19, 2024 04:55 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Eric-86sc
Apr 3, 2016 03:52 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
