Rear drums lock up, with very little pedal pressure, what is wrong???
Car: 1990 Chevy Camaro RS
Engine: 3.1 soon to be 305 or 350
Transmission: auto 700R4
I have a 90 rs 3.1 with drums in the back, a week ago my booster went out, so i replaced it ( that was hell LOL)(the top right bolt under the dash was not fun) anyways, now my rear brakes lock up and squall if i have to stop a little suddenly, NOTE it happened a little bit before the booster went out, but now it is rediculous, and when they don't lock up, when i am light on the pedal when i get close to a stop you can feel them griping hard like they are fixing to lock up, any suggestions? i got the booster from a junk yard, and used my same rod with the bad one that was on mt car already
Car: 92 Firebird vert
Engine: 388ci
Axle/Gears: 3.23 open
Sounds like your proportioning valve is messed up or you have a blockage in your brake lines. The valve is below the master cylinder and has steel tubes in and out. They sell adjustable ones also thru Summitt or Jegs. The valve takes the fluid pressure and sends more to the front brakes and less to the rear.
thanks alot, can i get one from autozone though? this is a daily driver and i really like to fix it today w/o waiting on shipping????
that would make sense i guess, because it really feels like the fronts are not even working, like the whole load is on the rear
Car: check
Engine: check
Transmission: check
May want to check the rear brake shoes. The shoe with less material on it goes toward the front. Folks have a natural reaction to having the shoe with more material on it to be incorrectly placed as the leading shoe.
RBob.
RBob.
1992 Trans Am
May 10, 2023 07:19 PM
I'llrocya
Feb 2, 2016 11:43 PM
