Help im an idiot
Car: 89' Iroc-Z G92
Engine: TPI 305 G92
Axle/Gears: Limited 9 bolt, 3.45
Help im an idiot
yeah, was just out with my buddies and i screwed up and kinda left the e brake on does anyone know what this will break, i cant find a pad anywhere on the rear, it is a J65 disc brake pics please
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Probably nothing happened, other than some faster-than-normal pad wear. If your parking brake still works, no worries.
Car: 89' Iroc-Z G92
Engine: TPI 305 G92
apeiron- yeah, where are the pads on the rear brakes it should look like the front right, the pieces on the caliper that bend just under the rim and then im guessing are supposed to connect to the pad, it still smells two hours later
TOMcat GTA
Sep 15, 2015 09:31 AM
