Brake light on!
Old May 2, 2005 | 10:58 AM
z28crazy's Avatar
Car: 86 Z-28
Engine: 356 4-bolt
Transmission: Borg warner T-5
Brake light on!
i recently had to put in new hard lines over th rear [the old ones blew open on me]. i disconnected the battery and did the work, i bled the system and the brakes work great. However the brake light continues to stay on. I read in the chilton book that there is a reset button the front brake potioning valve. ive pushed it and nothing new. Ive even disconnected the battery again, reconnected it and pushed the button as i started the car, but nothing changed. what do i do?
it is driving me nuts! its got to go!
Old May 2, 2005 | 03:54 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
if the brakes are fixed and theres no air in the lines, just push the pedal down.. it'll turn off
Old May 2, 2005 | 04:09 PM
z28crazy's Avatar
Car: 86 Z-28
Engine: 356 4-bolt
it doesnt turn off! ive been driving it like this for awhile. is there a sensor that could be bad? what else should i check?
Old May 8, 2005 | 09:13 PM
crazycrocket's Avatar
Car: 1985 camaro
I've had this happen on other gm vehicals. Find the brake light switch, remove it, and take it apart. Play with it a bit to see where it is sticking if you want, or just clean the thing out and put some WD 40 on the contacts and leave it for a bit. Reinstall and it should work fine.
Old May 9, 2005 | 06:43 PM
NoTransistors's Avatar
Car: '83 Firebird S/E
Engine: The Chevy 305. with carburator
Transmission: 700R-4
Not to be a wise-***, but WD-40 does not conduct current. It acts as an insulator. Contacts need to be clean and dry. I may not be a super car mechanic, but I do know about electricity.
Seth
wbrooks63
Exterior Parts Wanted
Oct 4, 2015 08:40 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
stalkier
Aug 21, 2015 01:54 AM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
