How do I adjust my E-Brake?...
Old May 2, 2005 | 11:33 AM
JerseyMark's Avatar
Car: 1991 RS Convertible
Engine: 96 LT1
Axle/Gears: 3.45 9-Bolt
Hey everyone,
I just installed a 4th gen rear. I got new E-Brake Cables but they seem to be a little short. My car doesnt have the adjustment nut at the equalizer. How do I adjust them? Right now I have the new cables on the car, but they are so tight that my E-Brake handle doesnt even pull them when I lift up. Almost like the handle broke.
Old May 2, 2005 | 11:47 AM
Axoid's Avatar
Car: 92 Camaro RS
Transmission: T5 manual
Is it a LS1 or a LT1 rear axle? Are you using parking brake cables for a 3rd gen or a 4th gen? Did you replace all three cables?
Old May 2, 2005 | 11:54 AM
JerseyMark's Avatar
Engine: 96 LT1
Its an LS1 rear axle, I am using new Raybestos BC94264 rear cables & the stock front cable.
I got the part # from this thread...
https://www.thirdgen.org/techbb2/sho...4th+gen+ebrake
Old May 2, 2005 | 12:12 PM
Axoid's Avatar
Car: 92 Camaro RS
I believe that the stock front cable is your problem. I installed LT1 brakes on my car over the winter and the guy that I bought them off of included the LT1 brake cables.
The LT1 front cable was about a 2" sorter than the 3rd gen cable and the two rear cables were longer that the 3rd gen cables. If it's the same with the LS1, you'll need to get a new front barking brake cable.
Pac J
May 17, 2020 10:44 AM
Mark_ZZ3
May 24, 2018 01:02 PM
383backinblack
Oct 14, 2015 08:50 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
