Connecting 89 line to 83 axle
Old May 2, 2005 | 04:50 PM
HawaiianRS's Avatar
Car: 1989 RS
Engine: 5.0
I'm doing a rear end swap (83w/disc into my 89 w/drum)and the issue of brake lines came up in another forum. Apparently the 83 is SAE flare while the 89 is an ISO flare.
Solution is to cut ISO flare off my 89's hardline and reflare it to SAE. Then just hook up the 83's rubber line.
Any problems with that, or is there something even easier?
Old May 2, 2005 | 08:08 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Spohn carries lines for your earlier threaded car, buy a set from him...no flaring needed.
http://www.spohn.net/product.cfm?productid=1478
Ed
Old May 4, 2005 | 03:18 PM
HawaiianRS's Avatar
Car: 1989 RS
Engine: 5.0
Thanks Ed, the problem is in hooking my 89 braking system to the 83 rear end, the fittings are different.
Old May 4, 2005 | 08:30 PM
ebmiller88's Avatar
OH, easy solution: Buy new lines from Fine Lines or Inline tube for a '88 model car with J65 brakes, problem solved and you'd get new lines to boot. It'll run you around $35-40 shipped. I wouldn't mess with trying to hook up the older, standard thread lines. Too much hassle when a simple line swap will do it.
Ed
Old May 5, 2005 | 12:50 PM
HawaiianRS's Avatar
Car: 1989 RS
Engine: 5.0
Thanks Ed,
I'm guessing you're talking about swapping the hard lines? I'm going even easier than that and having classic industries make me a new flexible line with metric on one end and SAE on the other for $30.
Genopsyde
Oct 7, 2015 08:35 PM
red90IROCls1
Aug 25, 2015 06:56 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
