LS1 Rear Brake Upgrade
Old May 7, 2005 | 10:50 AM
DTL504's Avatar
Car: 84 Z28 Convertible 2 Seater
Engine: Dart Little-M SBC 400
Transmission: Pro-built Automatics 700R4
Axle/Gears: Strange Engineering 3:73
I just received a LS1 rear brake upgrade kit, however one of the caliper pins rubber boots are missing and E-Brake boots are torn and needs to be replace.
Where can I get these parts from? If you have the part# please post.
Thanks: Dave
Old May 13, 2005 | 01:11 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
I dont know where to get the ebrake boots, but the pin boots can be had in a kit from Brakeware p/n H5927 avail at Autozone.
Old May 13, 2005 | 10:14 AM
DTL504's Avatar
Thanks for the part#, I went to AZ and the bonehead behind the counter could not find the part....
What are the qualification for working at Autozone? Is it a must to know about auto or is it just a hit and miss draft....
Old May 13, 2005 | 08:13 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
afaik they arent reproducing the ebrake boot yet, so the only way to get one is by buying the whole backing plate assembly from gm, $$$$$
Old May 13, 2005 | 08:19 PM
DTL504's Avatar
Thanks for the info, I will look in the boneyard to see if can find something decent.
Frozer!!!
Jan 19, 2024 04:55 PM
sailtexas186548
Jan 19, 2016 12:21 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
86White_T/A305
Aug 17, 2015 12:16 AM
sailtexas186548
Brakes
Aug 13, 2015 11:47 AM
