Drum to Disc?
Old May 23, 2005 | 10:40 PM
Alex_Camaro's Avatar
Drum to Disc?
Now I've been reading up on this and want to know what you guys think, looking for some serious advice here....
I could simply do a drum rear end swap to a disc rear end swap, but from what I know, isn't the disc setup only a 9 bolt, and have oddball size bearings etc, and the drum brake setup is a 10 bolt, with more common and cheaper bearings and the like? I want to build a solid car thats going to have a decent amount of torque thrown at it and don't want to be scattering an oddball rear end and forced to spend way too much money on it.
That said, is there any form of backing plate etc you can get to still use the 10 bolt? or am I completely lost in this whole subject? Just lookin for some advice/knowledge and wanna pick your brains.
The car is an 89 Trans Am GTA/WS6.
Old May 24, 2005 | 09:34 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Search for "Disc swap" :
https://www.thirdgen.org/techbb2/sho...ight=disc+swap
Both 9 and 10 bolts could have rear discs, the better sytle being from '89-92. They can be bolted onto either a 9 or 10 bolt rear with correct backing plates. Don't waste your time or money on '88 or older discs, go with the '89-92 PBRs with 10 bolt plates and have fun. PM me if you have any other questions, I have a ton of rear disc parts in the shop and may have what you need.
Ed
smnichol86
Brakes
26
Mar 26, 2017 10:55 PM
jrdturbo
Mar 31, 2016 02:58 PM
92projectcamaro
Dec 8, 2015 12:25 AM
KO1
16
Oct 15, 2015 05:00 PM
indygene
Sep 26, 2015 11:21 AM
