Difference Between 1LE and stock brakes
Old Jul 1, 2005 | 08:06 PM
TexasB4C's Avatar
Car: 92 Camaro B4C 350
I have 1LE brakes front and rear. Whats the difference between stock brakes and 1LE brakes???
Old Jul 1, 2005 | 09:02 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
standard front brakes are 10.5" rotors, single piston iron calipers, 1le are 12" rotors, dual piston aluminum calipers. iirc the rears are the same, unless ofcourse you have drums
Old Jul 2, 2005 | 06:45 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The pics in the following link will show calipers, rotors, and backing plate (standard to 1LE):
https://www.thirdgen.org/techbb2/sho...hreadid=246768
JamesC
Old Jul 2, 2005 | 01:51 PM
RTFC's Avatar
Car: Agood2.8,
Engine: V6rsr,
Transmission: Afrikingoodtime
Re: Difference Between 1LE and stock brakes
technically, 1LE and stock can be the same exact thing based on factory options your particular car came with
How to tell?
Simply measure the diameter of your rotors.
1LE rotor measures 11.65"
baseline brakes measure 10.50"
It is also possible to have 1LE rears and baseline fronts from the factory on certain years (I believe it was 89 1/2" through 92 that some cars had a combination of the two)
Old Jul 2, 2005 | 02:33 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
There actually aren't any "1LE" rears, the 1LE cars had the same J65 rears that were used on every car starting in 89.
Vintageracer
Jan 10, 2020 05:33 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
redmaroz
Aug 16, 2015 11:40 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
jpearcy1
Wheels and Tires
Aug 9, 2015 10:20 AM
