Air in system
Old Jul 6, 2005 | 01:55 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Air in system
A while ago I changed over from a drum rearend to a disk rear end. I used the 1LE calipers and rotors, the ribbed aluminum years. I routed and flared new brakelines, added Earls braided brake lines and got a rebuilt MC from Auto Zone. I used the Wilwood Adj. prop. Valve per the tech article. I now have the problem of having air in the lines.
I have bleed the whole system. It has seen at least 1 gallon of fluid through the whole system. However every time I bleed the brakes I get air escaping. The E-Brake is more of a novelty item now also. It just barely works. When I press on the pedal while driving it the car stops while pulling to the right. None of the brakes will lock up though, even on a gravel road. The pedal will almost go down to the floor. Is it possible that the Master cylinder is bad or I have a leak at one of my flares?
Old Jul 6, 2005 | 02:40 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
did you bench bleed the master cyl?
Old Jul 7, 2005 | 09:11 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Yes, I bench bleed the Master cylinder when I first put it on and I also rebleed it yesterday.
Keith5
Aug 27, 2015 04:37 PM
theurge
Aug 21, 2015 12:46 PM
overdriv
Aug 20, 2015 03:52 PM
bryan623
Aug 10, 2015 11:33 AM
