Distance?
Old Jul 12, 2005 | 07:18 PM
87calais's Avatar
Distance?
Hey guys, tried this in the rear end section, they said to try here, so here goes. I have a rear end that I want to put disc brakes on, it's a ford 9 inch, but I was wondering if anyone could tell me the distance between the axle flange and the backing plate on the axle? Thanks, I'm hoping to use a third gen brake setup....
Thanks again
Tim
Old Jul 12, 2005 | 07:35 PM
kevinc's Avatar
Car: 1982 Z28
The backing plate bolts directly to the axle tube flange, so the distance between them is pretty microscopic...
Old Jul 12, 2005 | 07:36 PM
87calais's Avatar
I mean the distance between the axle flange... the part on the axle itself and the mounting pad to the backing plate, the part on the axle tube.
Old Jul 13, 2005 | 01:56 AM
RTFC's Avatar
Car: Agood2.8,
Engine: V6rsr,
Transmission: Afrikingoodtime
GM 10-bolts on 3rd gens are a 2.75" offset from axle flange surface to housing flange surface.
Fords 9" rears can be either a 2.50" offset of a 2.36" offset base on the style of bearing flanges you have on the housing.
Old Jul 13, 2005 | 08:45 PM
87calais's Avatar
Awesome, that was what I was looking for... thanks
Prodigious
Nov 7, 2020 09:23 AM
AUZ28
Oct 3, 2015 06:28 PM
2MNYMaros
Sep 15, 2015 11:36 PM
blackandblue02
Sep 10, 2015 08:19 PM
