Stiffer brake lines?
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
I've read a few threads about replacing stock rubber brake lines with braided steel for a stiffer feel and it'll last longer. I can't really find a definite answer on whether its acceptable for a daily driver or a worthy investment. If so, are there any preferred brands and places to order?
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
They're definitely worth the money. I went with the Earl's lines too, and got them from Summit. I've heard bad things about the fittings used on Russell lines so you should probably stay away from those.
I believe the Earl's lines are even DOT approved.
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Re: Stiffer brake lines?
) Thread
