Rear disc question
Old Jul 26, 2005 | 11:33 AM
Slowmaro91RS's Avatar
Car: 91 Camaro RS
Axle/Gears: 10 bolt posi/3.23
Rear disc question
I just got a 3.23 posi rear with disc brakes from a 91 Z28. This car didn't have the dual piston calipers in the front so do I still have to change my proportioning valve? The guy i got it from said no but I'm still not sure and everything seems to be working fine with the old one.
Old Jul 26, 2005 | 11:05 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
If you are changing out a drum rear to disc yes you have to change the proportioning valve. If the car already has 4 wheel disc brakes and you are just upgrading to the newer style rear PBR brakes then you already have the correct proportioning valve.
Old Jul 27, 2005 | 09:26 AM
Car: 91 Camaro RS
Thanks, I wasn't sure how that worked. This was my first rear disc conversion.
Old Jul 27, 2005 | 10:30 AM
sjc115's Avatar
Car: 1984 Camaro
Engine: 350, 4bbl
Axle/Gears: GM, 3.23 posi
Slowmaro91RS: I see you are from around the Pgh area. Do you autocross your RS? If so who which club do you usually run with?
Have you ever taken it to the 'Flashlight Drags' (www.alteredgas.com)'?
Old Jul 27, 2005 | 09:02 PM
Car: 91 Camaro RS
Actually I'm still in the process of finishing my car. I really haven't had a chance to race it anywhere other than the street. Where are you from? I'm usually out in Irwin. If you're close by rmail me. There are a few good car shows out my way every week.
Old Aug 6, 2005 | 12:42 PM
KnightWarrior's Avatar
Car: 1985 Camaro Z-28
Engine: 305 V-8 4BBL (H) Supercharged
Axle/Gears: 3.42 Eaton Posi
Where is the proportioning valve located and what does it look like?
Old Aug 6, 2005 | 01:29 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Under the master, looks like a machined piece of aluminum with lines coming out of it.
Ed
Old Aug 6, 2005 | 01:30 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
On older cars they're cast instead of machined.
Old Aug 7, 2005 | 12:38 AM
What happens if you don't change it when going to rear discs from drums?
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
sailtexas186548
Jan 19, 2016 12:21 PM
redmaroz
Aug 16, 2015 11:40 PM
