brake lines by master cylinder
Car: 86 Camaro
Engine: none
Transmission: none
Axle/Gears: GT4, 3:73s
Im replacing all of the brake lines on my car due to rust. my question is do i have to make all the silly bends up by the master cylinder like the factory ones. Any special purpose those are like that?
Car: 83 TA, 89 TTA, others
Engine: ZZ4 TPI, LC2 turbo v6
Transmission: several, mostly broken
They're there for stress relief. You need to have some slack available in the system somewhere, or you're much more likely to burst a line in an accident or off-road incident, etc.
There's also some degree of movement in the M/C when you stomp the pedal (although ideally there woudn't be any; the factory mount isn't quite as rigid as it could be), so the loops help allow for that, in addition to allowing you to change the vacuum booster without having to disconnect the M/C.
HTH,
HTH,
Car: 1991 Chevy Camaro
Engine: 305 TBI
HTH,
HTH,
25thannivZ28
Aftermarket Product Review
Jan 2, 2016 05:41 PM
