brake upgrade q/a
Old Sep 8, 2005 | 05:55 PM
mrfbody's Avatar
brake upgrade q/a
this is what i want. aluminum preferrably 2 or more piston calipers all the way around.
what i have: disc brakes all the way around. i started with that funky 9bolt disc rear but swapped to a disc 7.5 in 10 bolt rear.
info i need. which swap is the EASIEST based on the criteria i supplied above.
thanx.
Old Sep 8, 2005 | 09:33 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Honestly they're all fairly easy as most upgrades are of the same type...2 piston PBR calipers with slip fit rotors. First off, what size wheels will you be running? Second, give a bit more info on your car like year model and what rear discs do you have..
I'd recommend C4 or C5 brakes with PBRs out back, maybe Wilwoods up front if you want a little extra power.
Ed
Old Sep 8, 2005 | 09:50 PM
mrfbody's Avatar
as mentioned in the pm i sent. i will put on the brakes 1st and pick rims around that.
it is a 87 GTA with the ws6 package and whatever else comes on a gta.
it is a work in progress. the story. i bought it 1/2 way through a lt-1 swap. it has the following lt-1 motor, 700r4 tranny(argh). suspension wise so far it has all new bushings and end links in the rear, new rear panhard bar, koni 3 way adjustable shocks, subframe connectors and i just came into a set of rear eibach 1 inch lowering springs for the rear and will either get the matching 1 inch springs or the 2 inch springs for the front.
i plan on doing much more to the suspension.
id like to use 17 inch rims but if i have to go bigger i will.
did you read my post about wbody brakes? what do you think about that as well?
only thing i am not flexible on is i have to have aluminum calipers all around, no steelies. and id like to not have to mess with switching any hubs.
i haven't checked but i do not believe it has the 1le front brakes. as far as the year of the rear brakes i am not sure. id say they are close though. both have the steelie single piston rear calipers and i think it has the steelie front calipers as well.
as far as future plans engine mods(probably be happy with 350-400 crank hp) and major weight reduction to help that suspension out as well as the brakes
edit: no wilwoods too much $$$ not enough brake. wth are pbr's what did they come in? can you im or pm me real quick so i can discuss options/prices real quick??????
Old Sep 12, 2005 | 11:53 PM
mrfbody's Avatar
oops....nvm
Old Sep 13, 2005 | 12:58 AM
V6#20's Avatar
Some people have no clue as to what they post. Tell me this after I hammer them and put you through my windsheild. I have the most powerful brake setup under a 16" rim you will ever see, and yes they are Wilwoods. Wilwoods are one of the least expensive calipers out there also when you start price shopping the Brandname overpriced Brembo's, Motive's, AP's..etc
Old Sep 13, 2005 | 06:54 PM
MurcoRS's Avatar
Car: 1989 Camaro RS
Engine: ZZ4 350
Axle/Gears: BW 9-bolt w/3.73
Even with the cheapest PBR set-up you're looking to spend over $1,000 for the front and rear swaps....
Old Sep 13, 2005 | 07:52 PM
mrfbody's Avatar
i re-iterate. what are pbr's? are they an acronym for an aftermarket company? is it a brand that gm used in certain cars... what?
right now i am thinking either c4 or c4hd for front(depending on price) and ls1 fbody on the rear.
Old Sep 13, 2005 | 09:25 PM
ebmiller88's Avatar
(Bobby, replied to your PM)
PBR:
http://www.pbr.com.au/index.shtml
They make the calipers for C4, C5, LS1, 1LE, Cobra, Mustang, and about every other aluminum dual piston caliper on the road. I think the front calipers on my Trailblazer are PBRs
Ed
Old Sep 13, 2005 | 10:07 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
so what are you doing with the car that wilwoods wouldnt be enough brake?
ps, ed, whats up with my stuff?
Old Sep 13, 2005 | 10:18 PM
ebmiller88's Avatar
Crap, Kyle...I left you hanging. I'll PM you in a few minutes, sorry.
Ed
Billy Decker
Sep 4, 2015 03:46 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
rudolphschenker
Sep 4, 2015 02:41 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
Night rider327
Sep 2, 2015 04:18 AM
