Corvette C5 Z06 Caliper
Old Oct 10, 2005 | 07:55 AM
DTL504's Avatar
Car: 84 Z28 Convertible 2 Seater
Engine: Dart Little-M SBC 400
Transmission: Pro-built Automatics 700R4
Axle/Gears: Strange Engineering 3:73
I'm in the process of gathering parts to do the C5 upgrade later in the winter. The calipers will be getting powder coating when my abutment bracket comes from www.GMPARTSDIRECT.com.
I bought the C5 calipers for the front and notice that the pistons has burns from what look like the disc pad had worn all the way down and was transfering heat to the pistons. The Vette shop that sold me the calipers rebuilt them (new rubber seals), but i was wondering about the pistons. At what point do you say its time to replace the pistons and what your opinion on stainless pistons?
Here is a photo:
Old Oct 10, 2005 | 07:58 AM
DTL504's Avatar
top of piston:
Old Oct 10, 2005 | 07:59 AM
DTL504's Avatar
Caliper:
Old Oct 10, 2005 | 05:06 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
As long as the pistons and the bores are smooth throw them back in. You could always just but new pistons and install them. Take a Scotch brite pad to them with some Fantastic or Simple Green and see how they turn out. As for stainless, they are supposed to be better than aluminum since they will transfer less heat than the AL pistons do. Depending on how hard you will push your car you might want to look into it.
Ed
Old Oct 12, 2005 | 05:35 PM
Zerstörer's Avatar
Car: 1992
Engine: 350TPI
How much improvement does stainless offer?
Old Oct 12, 2005 | 07:29 PM
ebmiller88's Avatar
Only benefit I know of is heat resistance..otherwise none.
Ed
Old Oct 13, 2005 | 08:21 AM
DTL504's Avatar
Ed
I sent you a PM, with a little wheeling and dealing proposal....
Old Oct 14, 2005 | 01:48 PM
DTL504's Avatar
Another PM from me:
David
Old Oct 14, 2005 | 10:34 PM
DTL504's Avatar
What a difference a little elbow grease make in cleaning the pistons:
Old Oct 14, 2005 | 10:35 PM
DTL504's Avatar
Top of Pistons:
Old Oct 15, 2005 | 05:29 AM
ebmiller88's Avatar
Yep, they usually clean up pretty well as most of the stuff is brake dust and bulidup on the upper part of the pistons close to the pad. I use Simple Green and a Scotch Brite pad. I have only had to replace 4 pistons or so in the 50+ calipers I've rebuilt over the last year. Internally they're usually good also.
I'll get back to you on the PM..
Ed
87v6Bird
Brakes
Oct 4, 2015 07:37 AM
the_hamturdler
Sep 30, 2015 12:50 PM
zayne0
Aug 24, 2015 07:22 PM
