Brakes and adequate vacume Q
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
How much vacume do you need to run power brakes on the street?
Also do you need more vacume when u upgrade to C5 set up?
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
My guess is 10-14", and stock vacuum is fine with C5s. If you need more, go with a vacuum pump and reservoir.
Ed
Ed
Engine: LS3
those vacume pumps aren't a big deal right? I just don't know much about them. Do I just hook up a vacume line to it and thats pretty much the gist of it, and it stores up vacume?
I might have to get one with my crzy cam i am running on the street.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
A vacuum pump would be either belt driven or electric. You'd run the brake booster line to it instead of the manifold.
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Vacuum pumps are quite pricey, close to $300 on Summitracing.com. I got a used one on eBay for $150 (an alternate place to look).
My suggestion, having done it, would be, don't buy one before you get the engine running. Build the engine and hook up a vacuum gauge. Judging by the results, then look to see if you need a pump or if you can get buy with a resevoir.
Car: Depends on what day it is..
Engine: Um, Chevy small-block
Transmission: One that shifts
Axle/Gears: Got those too...
11" of vacuum is very borderline. It could take time to replenish the vacuum if you are driving in stop/go traffic. But I agree with Stekman, run the car first and then decide if you need a vacuum pump.
Engine: LS3
Ok, thanks again. I would be in light traffic every now and then. So the vacume pump might be needed. And def an electric one. i am going out of my way to kepp under the hood looking clean, so no more pullies. 300 bucks doens't sound too bad i guess. I do need brakes, hehe.
In the event you do need to install a pump, Stainless Steel Brake Corp (SSBC) makes a decent pump for about $275. I just installed one on my buddy's car.
Good Luck.
Good Luck.
Engine: LS3
thx for the heads up.
I hear from my builder that I should be fine with a resivoir. (sp)
I hear from my builder that I should be fine with a resivoir. (sp) Thread
dbrochard
Sep 19, 2015 08:13 PM
