bajo bolt on front brakes
Old Nov 23, 2005 | 06:46 PM
vinceanity92's Avatar
Car: 1992 rs
Engine: 305 tbi
on stock front brakes do i need a washer under the banjo bolt? i took my stuff apart then just did total frontend rebuild and lost a few parts i think or i may have put the bajo bolt and washer in the core charge return i just forget if i needed that washer got a new banjo bolt but it pisses brake fluid every where when i tried to bleed them thanx for any replies
Old Nov 23, 2005 | 07:35 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Yes - there should be 2 copper washers that go in there - 1 goes between the banjo fitting and the caliper, the other goes between the banjo fitting and the bolt (a washer on each side of the banjo). You can get these copper washers seperately at any parts store - carry the bolt with you to get right size.
Old Nov 24, 2005 | 01:53 AM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Its really not a big deal that you lost them. The proper procedure is to replace them anyway.
Old Dec 15, 2005 | 06:34 PM
gearhead0384's Avatar
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
Dont reuse the old copper washers they might leak on you, always get new ones.
Kevin
Frozer!!!
Jan 19, 2024 04:55 PM
Terrell351
Jun 13, 2021 01:13 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
Eric-86sc
Apr 3, 2016 03:52 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
