Lines
Old Dec 3, 2005 | 02:00 AM
pbellsound's Avatar
Lines
Hey guys, I blew one of the rear lines from the T-hose to the drum on my 89. What size brake lines are these and approx. how long of pre-flaired straight line should I get for the left and right sides?
Thanks!
PB
Old Dec 3, 2005 | 02:55 AM
sixtyV6's Avatar
I am not sure if the '89 cars had different rear fittings than the '87 cars, but here's the best help I can give.
I know that '89 was the cutoff year for the thead pitch change on the propertioning (combination) valves and they have pre-89 and post 89. So '89 cars were some old style pitch threads, some new style pitch threads, but again, I think that only pertained to the front of the car near the combo valve.
Anyways, when I converted my rear brake setup from drums to disc I needed a new shorter hardline that ran from that "T" fitting to the drivers rear caliper. I bought this line directly from the in-store supplies at Autozone and the fitting size screws directly into the "T" fitting. Look for this part # and then another line with the same fittings but just longer length for the length you need. You'll most likely need one about 26-30" long instead of the 20" line I show below
Its the part# in the green box below
Old Dec 3, 2005 | 04:50 PM
pbellsound's Avatar
Hey sixtyV6!
Thanks for the info. I found the 4.762 means 3/16 line. The dude at Auto Zone took me in the back to find the right line and I came out with a 30 inch piece. After bending it exactly like the original, the length was perfect, no cutting or flairing was needed. The car stops like a champ again with it's 1LE fronts and drum rears.
You the man!
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
romcjr
Sep 17, 2015 05:18 PM
TBRays98
Sep 6, 2015 05:05 PM
