Rebuilt caliper or buy caliper rebuild kit?
Old Dec 4, 2005 | 09:28 PM
BigWhiteGTP's Avatar
Car: 1994 Trans Am
My RR caliper is bad, so I will either replace it or rebuild it. Does rebuilding the caliper take long? 1-2 hours, less than 1, what is the time table for a first timer?
And what is more reliable of the 2 options?
Old Dec 4, 2005 | 09:41 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
More reliable and quicker: rebuilt caliper. PBRs don't take that long, I can do one in 20 minutes or so assuming I don't have to replace any damaged parts. Usually they're OK, just dirty as hell. It depends on the overall condition. If it's really bad just replace it with a rebuild.
Ed
Old Dec 5, 2005 | 12:12 AM
Car: 1994 Trans Am
So do you think I should try and rebuild it and if it's still F'ed up, just buy a rebuilt one?
One more question, do the reman'd ones come with that bracket that goes over the disc, what is that bracket called?
Old Dec 5, 2005 | 09:12 PM
ebmiller88's Avatar
Loaded calipers will, standard ones will not but will come with guide pins and the e-brake cable bracket. Can you post a pic of it? I can't give a full recommendation without looking at it...which side is it anyway? I have a few extras and can swap it out with you for some cash..LMK. Pics would help.
Ed
Old Dec 6, 2005 | 12:01 AM
Car: 1994 Trans Am
Just got a rebuilt one. Much MUCH better condition than mine was. The bracket that attached to the ebrake spring on mine was bent beyond belief. I thought it was normal. *** I hope this is the end of this problem with the rear end. Oh and the passenger side axle saver I installed, but didn't need to because it was the driver side one that went bad,,,,,,,,is bad. Imagine that?!
-Kevin
hectre13
Dec 11, 2023 08:14 AM
italiano67
Dec 11, 2016 09:21 AM
backtothe80s
Sep 5, 2015 12:39 AM
hectre13
Aug 26, 2015 08:17 AM
