Coversion to Disc Brakes
Car: Camaro z28 1500 Truck Honda CBR900rr
Engine: 305 HO.
Transmission: 350 turbo
I want to convert my rear brakes to disc, any good post on what I need and how to.. I have a local salvage yard that just got in an 92 camaro with rear disc brakes. So I would like to know what I need and get it all at the same time.. I know I need the brake proporting value. I think that what its call.. Thanks for you help guys.
Car: 1991 Camaro RS
Engine: 383 LT1
Axle/Gears: 4.10
The proportioning valve is all I replaced. The master cylinder is the same. I take it you are replacing the whole rear end. That is what I did. If you are planning on just swapping brake parts, I am not sure what else you may need. Also, what year is your Camaro. If it is an 82 or 83, you may run into some SAE/Metric fitting conflicts with the 1992 parts.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
If the 92 has PBR's, grab them or the entire rear end.
https://www.thirdgen.org/techbb2/sho...hreadid=246768
The PBR's are the best brakes that GM offered.
JamesC
JamesC
If you currently have discs, the swap shouldn't be a big deal (I detail swapping from Delco Moraine to PBR's in the above link). If you now have drums, axel-flange modification is necessary.
JamesC
JamesC
Numbah-1
Sep 12, 2015 08:57 PM
drb930
Sep 9, 2015 10:53 PM
84 TA NV
Sep 6, 2015 08:02 PM
