braided brake lines for C5 upgrade(where?)
Old Jan 8, 2006 | 08:49 PM
BOTTLEDZ28's Avatar
Transmission: A4
I did some searching and cant find a place that sells new braided brake hoses (lines) that go from the chassis to the caliper for a C5 brake upgrade on the front. I have a 91z28 and Im pretty sure I have metric threads. Im pretty sure the C5 calipers are metric too but I havent got into the project yet to prove it. Spohn says they dont have what I need. I also have an LT1 disc rear and would like to add stainless lines back there as well but my main concern is the front right now.My car came with a drum rear. Who sells the lines i need to complete this swap. Im pretty sure I have already bought the C5 banjo bolts. I just need to get the crush washers.
Old Jan 9, 2006 | 06:05 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Just use a 1LE brake line. I have the brake lines you need for both the front (C5) and rear (LT1). LMK....
Ed
Old Jan 15, 2006 | 02:28 PM
Paul Riccioli Jr's Avatar
Car: 89 IROC-Z
Engine: 383
A company named Paragon makes then...do a search for stainless brake hoses and they should come up. They designed them for me when I did my swap. I think they are listed as just 82-92 F-body but they are actually long enough for the 1LE setup and the Z06 conversion. I was the prototype so I know.
Old Jan 15, 2006 | 03:10 PM
gixxer92's Avatar
Car: 1986 IROC, 2017 Silverado
Engine: 7.0L, 6.2L
Transmission: Tremec Magnum, 8L80
Axle/Gears: 3:23, 3:55
Well I found their web site but it wasn't up.
http://www.paragonperformance.com/
By chance do you have the measurements on the IROC's lines? I want to retain that intermediate connection and replace both hoses.
Old Jan 15, 2006 | 03:27 PM
Car: 89 IROC-Z
Engine: 383
Try calling them or check out the March issue of GMHTP in about 3 weeks....the part number will be in there.
Old Jan 15, 2006 | 03:56 PM
Car: 89 IROC-Z
Engine: 383
Found the part number in my records.... PPB-CHCAM8292
Old Jan 16, 2006 | 07:05 AM
ebmiller88's Avatar
I have Earl's 1LE front lines for $60, LMK.
Ed
Old Jan 16, 2006 | 08:25 AM
'Shifter's Avatar
Car: 87 Z-28
Engine: A worn-out 305
Transmission: T-5, until it dies
If you want to stay in town in the Tucson, AZ area, you can go see Bob at
Magills's Tubes and Hoses (690-0903)-he makes genuine DOT approved
stainless braided hoses of any sort with a clear, red or blue cover. I deal
with him all the time, mostly for a/c and oil cooler hoses, and I couldn't be
happier! Tell him Marc from Merles sent ya!
Old Jan 16, 2006 | 11:42 AM
gixxer92's Avatar
Engine: 7.0L, 6.2L
Ed
Ed, Is this both pieces on each side or is it all one piece of hose?
Old Jan 16, 2006 | 12:49 PM
ebmiller88's Avatar
Front pair of lines, one per side. One single piece per side, not a separate hose if that's clear.
Ed
Old Jan 16, 2006 | 01:32 PM
gixxer92's Avatar
Engine: 7.0L, 6.2L
Yeah that is what I was wonderin, because there is still that intermediate junction with the rubber line that attaches to the hard line. Does the 1LE line replace both of these pieces?
Tony
Old Jan 16, 2006 | 01:40 PM
'Shifter's Avatar
Car: 87 Z-28
Even your standard camaro hoses will work-can't speak for Ed's Earls hoses,
but my hoses have the 'bulkhead' (where the hose clips in) built in-I'm sure
the Earl's are the same.
Old Jan 16, 2006 | 05:30 PM
ebmiller88's Avatar
There's not a "junction" in the hose, that's just a steel mount to hold the line in the bracket, the line is never broken. Here is a pic of the Earl's lines I have. This was taken when I was doing my 1LE upgrade. The hose as seen here is not fully installed, just kinda hanging there. More pics are at the link in my sig....
See next post.
Ed
Old Jan 16, 2006 | 05:32 PM
ebmiller88's Avatar
This:
Old Jan 16, 2006 | 06:00 PM
'Shifter's Avatar
Car: 87 Z-28
This:
Yeah, like that!
Hey Ed! Still haven't swapped those adapters out....plate's been awful full...
Old Jan 29, 2006 | 07:57 PM
mpsoldier's Avatar
Car: 1991 Z28
Engine: LB9
Transmission: terrible700r4
this may be a dumb question, but in that pic just above what is that black piece that like runs around the caliper, holds the pads in there?
Old Jan 29, 2006 | 09:15 PM
Car: 89 IROC-Z
Engine: 383
Pad carrier
Old Jan 29, 2006 | 11:33 PM
mpsoldier's Avatar
Car: 1991 Z28
Engine: LB9
off hand do you know the GM part number for this pad carrier? for C5 vette. also the rear has them as well?
Old Jan 30, 2006 | 07:35 AM
Car: 89 IROC-Z
Engine: 383
I'd have to dig out the spreadsheet I have at home. Let me know if you can't wait a week. If you can, the March issue of GM High Tech Performance goes on sale next tuesday and my article on the C5 front brake swap will be in there complete with all the part numbers.
Old Jan 30, 2006 | 11:49 AM
ebmiller88's Avatar
C5 carrier (abutment bracket) is 12455799.
Ed
smnichol86
Brakes
26
Mar 26, 2017 10:55 PM
BADNBLK
Brakes
Oct 6, 2015 02:51 PM
dbrochard
Sep 25, 2015 04:56 PM
Necron
Brakes
Sep 14, 2015 12:45 PM
84 TA NV
Sep 6, 2015 08:02 PM
