rear e-brake spring & banjo bolt interference?
Old Jan 11, 2006 | 01:50 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I'm bending new hardlines on my rear axle, which is on a stand, and i'm trying to remember where the factory lines were, or, where is a good place to put them.
My main concern is putting the hard lines where they won't be affected by springs, LCA's, etc, but now i'm noticing the e-brake return spring, is right above the banjo bolt on the caliper.... It actually looks like it'll interfere, is this ok? I can't remember what it looked like when I removed it, but i'm certain i've got the left caliper on the left side, right on right side, but....
Anyone have a picture of their rear e-brake spring area? I can snap a picture of what mine currently looks like if it helps.
This is factory rear discs.
Thanks!
Old Jan 11, 2006 | 05:16 PM
88Iroc-R4race's Avatar
Car: 88 Iroc
Engine: tree fitty
Transmission: auto
for the iron caliper rear disc, the line came out the elbow towards the rear, then there is a bend inward and the forward to allow operation of the p/brk.
i will try to get a pic next time i have the wheel off (especially if you haven't figured it out by then)
Old Jan 11, 2006 | 05:45 PM
Sonix's Avatar
Car: 1982 Trans-Am
well, the bolt head that holds the banjo block down seems to be in the way of the parking brake spring right now....
I'll snap a pic tonight and show, maybe i've got something on bass ackwards or something.
Old Jan 11, 2006 | 10:47 PM
Sonix's Avatar
Car: 1982 Trans-Am
pic1
pic2
Hope those are clear enough. Is that right? Is something backwards? Maybe if someone has a picture of a rear caliper with e-brake assembly I can point out what I mean more clearly, but the banjo bolt and block are directly under the middle of the spring....??
Old Jan 12, 2006 | 05:33 PM
Car: 88 Iroc
Engine: tree fitty
Transmission: auto
well there one thing i do see wrong in the pic, the spring is installed incorrectly
it should be seated over the end of the lever circled in red
Attached Thumbnails rear e-brake spring & banjo bolt interference?-spring_and_bolt2.jpg
Old Jan 12, 2006 | 05:55 PM
Sonix's Avatar
Car: 1982 Trans-Am
ooooohhhhhhhhh..... ok, thanks! I'll give that a shot and see if I can get on there.
Old Jan 12, 2006 | 06:39 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
I installed a nine bolt with these brakes over the holidays. The banjo bolts were tight against the spring but could be removed and installed with the spring in place with a little effort. Once you get the spring on the right perch you'll have more room. If you're still having trouble let me know and I can send you a photo.
I just got the recall kit in today so I'll be pulling them off this weekend anyway.
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
sailtexas186548
Aug 26, 2015 03:32 PM
86White_T/A305
Aug 17, 2015 12:16 AM
