drum to dics
Old Jan 31, 2006 | 02:12 PM
The Chad's Avatar
Car: 84 berlinetta
Engine: lg4
Transmission: 700 r4
drum to dics
Made the coversion to 89 9 bolt. The braking power should be 50-50 as a search gave me this info? Is the proportional valve 3/8?
Old Feb 2, 2006 | 06:44 PM
The Chad's Avatar
Car: 84 berlinetta
Engine: lg4
I meant to say 3/16. Can any body recomend a proportional valve to me. Old valve is 70/30 with front dics and originally rear drums. Is that correct. Braking did'nt seam to bad last fall as I remember.Has anybody just kept old valve and been sastisfied with their braking.
Old Feb 3, 2006 | 10:50 AM
Bens3rdGen's Avatar
Car: 91 Camaro RS
Engine: Holley MPFI, AFR 195, Hot Cam=375HP
I'd just get a valve for a 4-wheel disk car. You probably won't notice if you have bad rear braking unless you lock up the wheels sometimes.
Also, there is a residual (sp?) check valve that I thought was built into the master cylinder. It keeps a little pressure in the rear lines. This was designed to work against the heavy spring pressure of your drums but it will make your disks drag. I can't remeber where the valve is, hopefully someone can chime in hear, but you need to make sure it's removed.
Ben
Old Feb 7, 2006 | 09:46 PM
camaro430sut's Avatar
Car: 89 Camaro/ 02 GC Overland
Engine: 355 V8/ 4.7 HO V8
Transmission: T5/ 545RE
Axle/Gears: 10 Bolt 3.73/ Dana 30, Dana 44 3.73
9 bolt brakes
i just bought a 9 bolt disk rear. for some reason one caliper is facing towards the front and the other is toward the back. which one is it supposed to be?
smnichol86
Brakes
26
Mar 26, 2017 10:55 PM
92projectcamaro
Dec 8, 2015 12:25 AM
Prodigious
Sep 18, 2015 05:23 AM
Prodigious
Sep 18, 2015 05:18 AM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
