baer prop valve
Old Feb 2, 2006 | 09:32 AM
FullSendRacing's Avatar
Car: '85 Trans Am FAILBIRD
Axle/Gears: 4th gen torsen 3.42
baer prop valve
I've got the baer pro kit up front and the track kit in back. I want to put in the 2000035 adjustable proportioning valve but I'm not sure about how it's installed. I believe it just goes in line with the rears below the factory valve. Can anyone verify that?
Old Feb 2, 2006 | 09:45 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
every aftermarket brake prop valve ive ever seen REPLACES the stock prop valve. it does not go inline.
Old Feb 2, 2006 | 10:01 AM
Well, I know the wilwood is meant to replace the stocker, but I think some are meant to just go inline to the rears, as Dean explained in this thread: https://www.thirdgen.org/techbb2/sho...le+brake+valve
You get to keep the redundancy for safety, and your brake fault light will still work.
Just wondering if anyone has done one like this - I believe the valve I have is meant to go inline, but not sure. I might have to get on the horn with Baer.
Old Feb 2, 2006 | 11:26 AM
Jetmeck's Avatar
Car: '89 GTA 9,000 MILES
Axle/Gears: 3.27 9 bolt
Unless you gut the rear side of the factory combo/proportioning valve you would be wasting your time putting in an adjustable valve. I follow the thinking of keeping the factory idiot light operational. You need 100% pressure going to the adjustable valve then start adjusting it down.
There is another thread on here about using a 4th gen MC that has a low fluid warning switch built into it that I am looking into so I could completely remove the factory valve and still keep the idiot light functional. Course then I would put in the adjustable valve in the rear line and a line loc in the front. SOUNDS like the best of all worlds if it works.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
Necron
Brakes
Sep 14, 2015 12:45 PM
84 TA NV
Sep 6, 2015 08:02 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
