power to manual conversion?
Old Feb 22, 2006 | 08:13 AM
LETZ RUN's Avatar
Car: 1986 ****** Camaro
Engine: 355
Transmission: th350
Axle/Gears: 3.42 10 bolt - temporary
What do I have to do convert my brakes to manual so I can lose that giant booster thing? Do I need a different master cylinder? Anyone have any ideas?
Old Feb 22, 2006 | 04:44 PM
LETZ RUN's Avatar
Engine: 355
Transmission: th350
fyi it already has 4 wheel ls1 brakes.. i just want to convert it to manual.. where there any thirdgens with manual brakes? can i just buy a manual master cyl and call it good?
Old Feb 22, 2006 | 06:18 PM
Steve51186's Avatar
Car: 1984 Trans-Am
Transmission: auto
Dude.....Nooooooooooo
Old Feb 22, 2006 | 07:41 PM
LETZ RUN's Avatar
Engine: 355
Transmission: th350
why not?
Old Feb 22, 2006 | 09:35 PM
Steve51186's Avatar
Car: 1984 Trans-Am
Transmission: auto
1. It is way more difficult to stop a car with out vacuum assist.
2. That would never pass inspection.
3. I would never want you to be driving behind me.
Old Feb 22, 2006 | 09:41 PM
xplane's Avatar
Car: 85 camaro sport coupe
Engine: 2.8 MFI
Transmission: v6 700R4 wish it was a 5spd Stick
Axle/Gears: Stock non posi 3.42s
I can think of one reason why: you have a fairly large brakes setup on the car meaning your gonna need a lot more pressure to make it work effectively. Plus how much weight do you think your gonna by taking the Vac assist off? 3, mabe 4 pounds? whoop de do and it the meantime you have made your car into a death trap.
Old Feb 22, 2006 | 11:04 PM
Dave_Jones's Avatar
Car: 83 TA, 89 TTA, others
Engine: ZZ4 TPI, LC2 turbo v6
Transmission: several, mostly broken
There'd be nothing unsafe about a properly done manual setup. And the LS1 calipers would work just fine.
To do the job right, you'd need to change to a non-quick take up MC, and possibly either reduce the MC bore diameter or increase pedal ratio to bring the pedal effort back to a level you're comfortable with. A manual setup will require a longer pedal stroke to achieve the same pedal effort.
Now, if what I just wrote wasn't already obvious to you, you may not have a good understanding of the fundamentals involved. I'd strongly suggest you read and understand Fred Puhn's brake book before proceeding. (FWIW, I prefer the vac assist setup )
Old Feb 22, 2006 | 11:15 PM
xplane's Avatar
Engine: 2.8 MFI
ya you can make it work but why? what will 3 or 4 pounds affect? there are many places you could loose more easier and safer.
Old Feb 22, 2006 | 11:17 PM
Dave_Jones's Avatar
Originally posted by xplane
...you have a fairly large brakes setup on the car meaning your gonna need a lot more pressure to make it work effectively.
Um, no.
More caliper piston area = less hydraulic pressure, to achieve a given piston (pad) force.
Larger rotor diameter = longer lever arm = less pad force required to achieve the same rotor torque.
Old Feb 22, 2006 | 11:26 PM
Dave_Jones's Avatar
If you don't mind the longer pedal stroke (or increased pedal effort; they're a tradeoff), there's nothing more reliable than a full manual setup.
Try stopping a power brake car with a booster failure sometime.
I haven't seen anyone wreck, but I have seen a couple of guys lose track days due to failed power boosters, when they didn't have a spare available.
Old Feb 23, 2006 | 08:29 AM
LETZ RUN's Avatar
Engine: 355
Transmission: th350
cam is going to be way to big to even help the vaccuum assist, thats my main reason. and to get that giant ugly looking booster out of the engine compartment.
jhawkeye
May 25, 2022 06:33 PM
Vintageracer
Jan 10, 2020 05:33 PM
sailtexas186548
Aug 24, 2015 10:11 PM
stalkier
Aug 21, 2015 01:54 AM
stalkier
Aug 13, 2015 12:59 PM
