banjo bolt question
Old Mar 23, 2006 | 06:01 AM
dyrt's Avatar
Car: 86 Regal Limited
Engine: 95 cop lt1
Transmission: t56
Axle/Gears: 8.5" gn/3.73 gears
banjo bolt question
howdy folks, with the new forum upgrade and such the search wasn't working so i can't search on this but i was just wondering if anyone knew if the 1le and ls1 banjo bolts were the same. i have a few 1les and would rather not deal with the dealer to get the ones for ls1(they have a different parts numbers) since they may be the same specs with just a different number. does anyone know? can anyone give me a few measurements from an ls1 banjo bolt? thanks for any help!
Old Mar 23, 2006 | 10:20 AM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
what exactly is a banjo bolt again?
Old Mar 23, 2006 | 11:25 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Used to attach brake line to caliper.
JamesC
Old Mar 24, 2006 | 01:10 AM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
how does it look or how is it different?
I knw guys where saying use one on my rx7's fuel rail went to replace the pulsation damper.
Old Mar 24, 2006 | 05:57 AM
JamesC's Avatar
Yours is a fuel inlet fitting. The banjo bolt is a hollow, threaded affair with a hole in the side. This passage allows fuel or brake fluid to flow.
JamesC
Old Mar 24, 2006 | 06:37 AM
JoBy's Avatar
Car: 1984 Corvette
Engine: Turbo 350
Transmission: 4L80E with TCI T-Com
Old Mar 24, 2006 | 06:40 AM
JamesC's Avatar
Exactomundo!
JamesC
84z96L31vortec
Aug 20, 2017 12:16 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
