rear brake line removal
Old Mar 25, 2006 | 07:12 PM
kaptinkafeen's Avatar
I'm currently pulling off my rear brake lines to instal earl's product -
I'm aving trouble pulling off the rear right flex brake line.
(GM 7.5" rear with 1LE rear calipers)
I have soaked the fitting with penetrating oil, heated the lex line's female end but still can't get the line free....
I'm at the point that the 12mm wrench that fit like a glove is starting to round off the hardline male fitting.
What do you guys recommend I do next before I end up cutting the flex line with a dremel to try and save the hard line fitting..
TIA
-Andrew
Old Mar 25, 2006 | 09:40 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Make sure to use flair wrenches. If you round it off and no wrench will fit, use a plumbers pipe wrench.
Last edited by Justins86bird; Mar 25, 2006 at 09:44 PM. Reason: Automerged Doublepost
Eric-86sc
Apr 3, 2016 03:52 PM
Reddeath210
Oct 6, 2015 08:20 AM
kyleb24
Aug 15, 2015 08:24 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
